Hi Guys,
I’m trying to find out if its possible to restart somehow a big (11TB) data import from an external USB drive formatted as ntfs.
I plugged the drive in and it seemed to start working fine. It transferred about 4TB over 12 or so hours but this morning I found that it had just stopped for no apparent reason (no errors I could see in the logs anyway) and I can’t seem to start it again (it throws errors about “Seperator not found and chunk exceeded limit” along with a bunch of python exceptions).
I guess the inbuilt software isn’t happy about starting again with data already on the target disk.
So… is there a way I can manually mount the disk and perhaps something like RSync I can use to pick up where I got too with the transfer?
I’m not seeing much online that helps me so far.
Thanks.
