Is there a way to have multiple DHCP enabled vlans on Truenas?
I have a LAGG setup with a VLAN but I want to add another VLAN just for DATA for iSCSI etc. I have static assignments in my DHCP server but Truanas only allows for one DHCP enabled interface. Is there a way to have it get DHCP addresses on both VLANs? (I dont want to add another nic to achieve this)
Truenas can only have one dhcp settings, just assign static IP to the other networks / vlans
You typically don’t want DHCP for services like iscsi and you don’t want this network to be routable(traffic isn’t going through the firewall). But, you can create an interface from your LAGG interface, just set the VLAN ID.
