All of Ubiquiti’s Edge line is passive POE. Passive is preferred in the WISP space where they know what they are plugging in where, and just want the power to be output for as low cost as possible.
The issue for powering common POE devices isn’t so much the active vs passive, its that passive POE is almost always just 24V while Active POE is “48V” (anything between 46 and 58V on the output side is within spec, and higher voltage is preferred for handling long cable runs). The reason is that almost all consumer electronics (laptops, desktops) would handle 24V passive but may be damaged by a higher passive voltage. They wouldn’t be using this power, so it would just be wasted heating up the transformers in the client device.
Depending on which switch you bought, it will be running one of two possible OS’s, and the means to access them are different.
The CRS326 you linked runs RouterOS by default. This is fine, and is actually the more feature rich of the two, but more features means more things to learn and possibly mess up. The preferred way to configure RouterOS is by downloading WinBox from Mikrotik, which can connect either by IP (layer 3) or even by just the MAC (layer 2). It includes a discovery probe on the login screen that shows all found Mikrotik devices, if you want to connect to your switch via layer 2 just click on the MAC for it to be auto-entered. The other methods to program the switch are by going to its IP in your browser, like a consumer router, this is called WebFig (web config). The third method is SSH/telnet. The fourth as you stated is console cable.
That switch can be swapped over to SwitchOS as well. SwitchOS is more focused on the essentials of what a L2 switch needs. It can only be configured via the browser. SSH/telnet won’t work, and connecting by console won’t allow you to see or change very much.
You linked the CRS326-24G-2S+RM - this is not a POE-Out switch. Its only POE feature is that the switch itself can be powered via POE, like an AP or Phone.
The closest POE-Out switch is the MikroTik Routers and Wireless - Products: CRS328-24P-4S+RM - this has both Active48V and Passive 24V POE on all 24 ethernet ports. Meaning you don’t have to worry about what type of device you’re connecting, it will either be detected by Active POE or you can enable passive 24V on that single port.
Like almost everything from Mikrotik, the value of the hardware and software (price to features) is unbeatable. But the cost is a high learning curve and sometimes a lack of polish around new features.
