Hello,
I need to virtualize some severs which the software is licensed to the hard drive serial number. I know that it is possible in Proxmox but wanted to know if it was possible with XO and if so how.
Hello,
The same could be asked about serial number for NIC, I have one application that is locked to one or both of these devices and I’d like to p2v this server.
I’m not 100% sure if this is what you are looking for but I know in XCP-ng center there is a way to add a custom field to devices
Or I know from XOA you can define custom fields in the advanced section of the VM
@xMAXIMUSx, thanks for your reply but that did not accomplish what I needed.
