I have Pfsense installed on a HP T620 with a 4 port 1g Nic. all these ports are use. foe WAN & LAN , Cameras & Lounge TV media etc
In noticed that the HP port re0 is not used . So I was thinking that i could use this port for Access Points.
Is this possible as i could configure it with a ip address 10.10.20.xx but i couldn’t set it up the DCHP server?
I do believe the best practice is to connect the AP to your switch, however, if it works then I suppose it will ok.
If you want to make use of your “extra” port on your router then I’d say you can create a LAGG between your router and switch, assuming it supports it.
In pfsense > interfaces > Assignments, do you see the port (different mac address) ? if so, it will be named opt1 (you can change it to AP) and configure the ip/dhcp for that network segment.
Thanks for reply… I seems to brick my system. I rebooted pfsense it seems as it has hasn’t bootup correctly. i have reset my whole system , modem,etc, pfsense and check that it has booted which i can see on a monitor all looks ok no errors . Should i reset to factory and restore from my latest config.xml ?
RE suggests a Realtek port, Realtek is not a great choice so it’s possible this OS can’t see it properly or doesn’t like it.
You should be able to reset to factory and restore your config, assuming that saved config actually loaded. You can also edit the config to remove anything that might be giving you problems, it’s just a text file.
Thanks for reply . I start for restore config. xml from 30th December .
Sorry for all question but am still new to Psfsense , when it working is fine but when it goes wrong , i struggle and spent a lot of time sourcing a solution. I will reset to factory setting.
how would alter the config ?
The only reason to edit it would be if you needed to remove and change the network ports from one device to another. Pretty common if you buy new hardware. Or if you added a 5th interface and then things broke.
If you saved the config before making the changes to add that 5th port, then you should be fine.
