I think i found the issue, but can´t resolve it
Take a look at the last part of the config. This error am i getting every time.
May 29 19:35:08 pfsense php-fpm[43595]: /rc.start_packages: Restarting/Starting all packages.
May 29 19:35:09 pfsense php: [pfBlockerNG] DNSBL parser daemon started
May 29 19:35:09 pfsense php-cgi: haproxy: starting old pid:none
May 29 19:35:09 pfsense php-cgi: haproxy: started new pid:41214
May 29 19:35:12 pfsense php-fpm[43595]: [pfBlockerNG] Starting firewall filter daemon
May 29 19:35:12 pfsense php_pfb: [pfBlockerNG] filterlog daemon started
May 29 19:35:12 pfsense php: [pfBlockerNG] DNSBL parser daemon started
May 29 19:35:13 pfsense getty[33237]: open /dev/ttyv0: No such file or directory
May 29 19:35:38 pfsense check_reload_status: Syncing firewall
May 29 19:36:59 pfsense check_reload_status: Syncing firewall
May 29 19:41:42 pfsense check_reload_status: Syncing firewall
May 29 19:42:53 pfsense check_reload_status: Syncing firewall
May 29 19:42:59 pfsense check_reload_status: Syncing firewall
May 29 19:43:00 pfsense check_reload_status: Syncing firewall
May 29 19:43:20 pfsense php: [pfBlockerNG] No changes to Firewall rules, skipping Filter Reload
May 29 19:43:28 pfsense check_reload_status: Syncing firewall
May 29 19:43:29 pfsense check_reload_status: Syncing firewall
May 29 19:54:02 pfsense check_reload_status: Syncing firewall
May 29 19:54:06 pfsense php: [pfBlockerNG] No changes to Firewall rules, skipping Filter Reload
May 29 19:54:08 pfsense check_reload_status: Syncing firewall
May 29 20:00:00 pfsense php: [pfBlockerNG] Starting cron process.
May 29 20:00:03 pfsense php: [pfBlockerNG] No changes to Firewall rules, skipping Filter Reload
May 29 20:28:27 pfsense php-fpm[345]: /index.php: Successful login for user ‘admin’ from: 192.168.166.204 (Local Database)
May 29 20:28:41 pfsense check_reload_status: Syncing firewall
May 29 20:29:03 pfsense check_reload_status: Syncing firewall
May 29 20:44:06 pfsense php-fpm[345]: /index.php: User logged out for user ‘admin’ from: 192.168.166.204 (Local Database)
May 29 20:44:21 pfsense php-fpm[345]: /index.php: Successful login for user ‘admin’ from: 192.168.166.204 (Local Database)
May 29 21:00:00 pfsense php: [pfBlockerNG] Starting cron process.
May 29 21:00:03 pfsense php: [pfBlockerNG] No changes to Firewall rules, skipping Filter Reload
May 29 21:14:39 pfsense check_reload_status: Syncing firewall
May 29 21:16:30 pfsense check_reload_status: Syncing firewall
May 29 21:19:03 pfsense rc.gateway_alarm[79877]: >>> Gateway alarm: WAN_DHCP (Addr:xxx.xxx.xxx.xxx Alarm:1 RTT:6.747ms RTTsd:5.981ms Loss:21%)
May 29 21:19:03 pfsense check_reload_status: updating dyndns WAN_DHCP
May 29 21:19:03 pfsense check_reload_status: Restarting ipsec tunnels
May 29 21:19:03 pfsense check_reload_status: Restarting OpenVPN tunnels/interfaces
May 29 21:19:03 pfsense check_reload_status: Reloading filter
May 29 21:19:03 pfsense check_reload_status: Linkup starting re0
May 29 21:19:03 pfsense kernel: re0: watchdog timeout
May 29 21:19:03 pfsense kernel: re0: link state changed to DOWN
May 29 21:19:04 pfsense php-fpm[346]: /rc.openvpn: Gateway, none ‘available’ for inet, use the first one configured. ‘WAN_DHCP’
May 29 21:19:04 pfsense php-fpm[346]: /rc.openvpn: Gateway, none ‘available’ for inet6, use the first one configured. ‘WAN_DHCP6’
May 29 21:19:04 pfsense php-fpm[346]: /rc.openvpn: OpenVPN: One or more OpenVPN tunnel endpoints may have changed its IP. Reloading endpoints that may use WAN_DHCP.
May 29 21:19:04 pfsense php-fpm[346]: /rc.linkup: DEVD Ethernet detached event for wan
May 29 21:19:05 pfsense check_reload_status: Reloading filter
May 29 21:19:06 pfsense kernel: arpresolve: can’t allocate llinfo for xxx.xxx.xxx.xxx on re0
May 29 21:19:07 pfsense kernel: arpresolve: can’t allocate llinfo for xxx.xxx.xxx.xxx on re0
May 29 21:19:07 pfsense check_reload_status: Linkup starting re0
May 29 21:19:07 pfsense kernel: re0: link state changed to UP
May 29 21:19:08 pfsense php-fpm[346]: /rc.linkup: DEVD Ethernet attached event for wan
May 29 21:19:08 pfsense php-fpm[346]: /rc.linkup: HOTPLUG: Configuring interface wan
May 29 21:19:08 pfsense check_reload_status: rc.newwanip starting re0
May 29 21:19:08 pfsense php-fpm[346]: /rc.linkup: calling interface_dhcpv6_configure.
May 29 21:19:08 pfsense php-fpm[346]: /rc.linkup: Accept router advertisements on interface re0
May 29 21:19:08 pfsense php-fpm[346]: /rc.linkup: Starting rtsold process
May 29 21:19:09 pfsense check_reload_status: Syncing firewall
May 29 21:19:09 pfsense php-fpm[40423]: /rc.newwanip: rc.newwanip: Info: starting on re0.
May 29 21:19:09 pfsense php-fpm[40423]: /rc.newwanip: rc.newwanip: on (IP address: xxx.xxx.xxx.xxx) (interface: WAN[wan]) (real interface: re0).
May 29 21:19:10 pfsense php-fpm[346]: /rc.linkup: Gateway, none ‘available’ for inet, use the first one configured. ‘WAN_DHCP’
May 29 21:19:10 pfsense php-fpm[346]: /rc.linkup: Gateway, none ‘available’ for inet6, use the first one configured. ‘WAN_DHCP6’
May 29 21:19:10 pfsense check_reload_status: Restarting ipsec tunnels
May 29 21:19:15 pfsense check_reload_status: Syncing firewall
May 29 21:19:15 pfsense check_reload_status: updating dyndns wan
May 29 21:19:15 pfsense check_reload_status: Reloading filter
May 29 21:19:24 pfsense check_reload_status: Syncing firewall
May 29 21:19:45 pfsense kernel: re0: watchdog timeout
May 29 21:19:45 pfsense kernel: re0: link state changed to DOWN
May 29 21:19:45 pfsense check_reload_status: Linkup starting re0
May 29 21:19:46 pfsense php-fpm[346]: /rc.linkup: DEVD Ethernet detached event for wan
May 29 21:19:47 pfsense check_reload_status: Reloading filter
May 29 21:19:48 pfsense kernel: arpresolve: can’t allocate llinfo for xxx.xxx.xxx.xxx on re0
May 29 21:19:49 pfsense kernel: arpresolve: can’t allocate llinfo for xxx.xxx.xxx.xxx on re0
May 29 21:19:49 pfsense check_reload_status: Linkup starting re0
May 29 21:19:49 pfsense kernel: re0: link state changed to UP
May 29 21:19:50 pfsense kernel: arpresolve: can’t allocate llinfo for xxx.xxx.xxx.xxx on re0
May 29 21:19:50 pfsense php-fpm[63138]: /rc.linkup: DEVD Ethernet attached event for wan
May 29 21:19:50 pfsense php-fpm[63138]: /rc.linkup: HOTPLUG: Configuring interface wan
May 29 21:19:50 pfsense check_reload_status: rc.newwanip starting re0
May 29 21:19:50 pfsense php-fpm[63138]: /rc.linkup: calling interface_dhcpv6_configure.
May 29 21:19:50 pfsense php-fpm[63138]: /rc.linkup: Accept router advertisements on interface re0
May 29 21:19:50 pfsense php-fpm[63138]: /rc.linkup: Starting rtsold process
May 29 21:19:51 pfsense php-fpm[58663]: /rc.newwanip: rc.newwanip: Info: starting on re0.
May 29 21:19:51 pfsense php-fpm[58663]: /rc.newwanip: rc.newwanip: on (IP address: xxx.xxx.xxx.xxx) (interface: WAN[wan]) (real interface: re0).
May 29 21:19:52 pfsense php-fpm[63138]: /rc.linkup: Gateway, none ‘available’ for inet, use the first one configured. ‘WAN_DHCP’
May 29 21:19:52 pfsense php-fpm[63138]: /rc.linkup: Gateway, none ‘available’ for inet6, use the first one configured. ‘WAN_DHCP6’
May 29 21:19:52 pfsense check_reload_status: Restarting ipsec tunnels
May 29 21:19:58 pfsense check_reload_status: updating dyndns wan
May 29 21:19:58 pfsense check_reload_status: Reloading filter
May 29 21:20:20 pfsense kernel: re1: watchdog timeout
May 29 21:20:20 pfsense kernel: re1: link state changed to DOWN
May 29 21:20:20 pfsense kernel: re1.171: link state changed to DOWN
May 29 21:20:20 pfsense kernel: re1.200: link state changed to DOWN
May 29 21:20:20 pfsense kernel: re1.172: link state changed to DOWN
May 29 21:20:20 pfsense kernel: re1.173: link state changed to DOWN
May 29 21:20:20 pfsense check_reload_status: Linkup starting re1
May 29 21:20:20 pfsense check_reload_status: Linkup starting re1.171
May 29 21:20:20 pfsense check_reload_status: Linkup starting re1.200
May 29 21:20:20 pfsense check_reload_status: Linkup starting re1.172
May 29 21:20:20 pfsense check_reload_status: Linkup starting re1.173
May 29 21:20:21 pfsense php-fpm[345]: /rc.linkup: Hotplug event detected for LAN(lan) static IP (192.168.166.1 )
May 29 21:20:21 pfsense php-fpm[63138]: /rc.linkup: Hotplug event detected for LAB_171(opt1) static IP (192.168.171.1 )
May 29 21:20:21 pfsense php-fpm[78137]: /rc.linkup: Hotplug event detected for GAST(opt3) static IP (192.168.200.1 )
May 29 21:20:21 pfsense check_reload_status: Reloading filter
May 29 21:20:21 pfsense php-fpm[345]: /rc.linkup: Hotplug event detected for IOT(opt2) static IP (192.168.172.1 )
May 29 21:20:21 pfsense php-fpm[63138]: /rc.linkup: Hotplug event detected for DMZ(opt4) static IP (192.168.173.1 )
May 29 21:20:24 pfsense check_reload_status: Linkup starting re1
May 29 21:20:24 pfsense kernel: re1: link state changed to UP
May 29 21:20:24 pfsense kernel: re1.171: link state changed to UP
May 29 21:20:24 pfsense kernel: re1.200: link state changed to UP
May 29 21:20:24 pfsense kernel: re1.172: link state changed to UP
May 29 21:20:24 pfsense kernel: re1.173: link state changed to UP
May 29 21:20:24 pfsense check_reload_status: Linkup starting re1.171
May 29 21:20:24 pfsense check_reload_status: Linkup starting re1.200
May 29 21:20:24 pfsense check_reload_status: Linkup starting re1.172
May 29 21:20:24 pfsense check_reload_status: Linkup starting re1.173
May 29 21:20:25 pfsense php-fpm[63138]: /rc.linkup: Hotplug event detected for LAN(lan) static IP (192.168.166.1 )
May 29 21:20:25 pfsense check_reload_status: rc.newwanip starting re1
May 29 21:20:25 pfsense check_reload_status: Reloading filter
May 29 21:20:25 pfsense php-fpm[63138]: /rc.linkup: Hotplug event detected for LAB_171(opt1) static IP (192.168.171.1 )
May 29 21:20:25 pfsense check_reload_status: rc.newwanip starting re1.171
May 29 21:20:25 pfsense php-fpm[63138]: /rc.linkup: Hotplug event detected for GAST(opt3) static IP (192.168.200.1 )
May 29 21:20:25 pfsense check_reload_status: rc.newwanip starting re1.200
May 29 21:20:25 pfsense php-fpm[63138]: /rc.linkup: Hotplug event detected for IOT(opt2) static IP (192.168.172.1 )
May 29 21:20:25 pfsense check_reload_status: rc.newwanip starting re1.172
May 29 21:20:25 pfsense php-fpm[63138]: /rc.linkup: Hotplug event detected for DMZ(opt4) static IP (192.168.173.1 )
May 29 21:20:25 pfsense check_reload_status: rc.newwanip starting re1.173
May 29 21:20:26 pfsense php-fpm[63138]: /rc.newwanip: rc.newwanip: Info: starting on re1.
May 29 21:20:26 pfsense php-fpm[63138]: /rc.newwanip: rc.newwanip: on (IP address: 192.168.166.1) (interface: LAN[lan]) (real interface: re1).
May 29 21:20:26 pfsense php-fpm[63138]: /rc.newwanip: rc.newwanip: Info: starting on re1.171.
May 29 21:20:26 pfsense php-fpm[63138]: /rc.newwanip: rc.newwanip: on (IP address: 192.168.171.1) (interface: LAB_171[opt1]) (real interface: re1.171).
May 29 21:20:26 pfsense php-fpm[63138]: /rc.newwanip: rc.newwanip: Info: starting on re1.200.
May 29 21:20:26 pfsense php-fpm[63138]: /rc.newwanip: rc.newwanip: on (IP address: 192.168.200.1) (interface: GAST[opt3]) (real interface: re1.200).
May 29 21:20:26 pfsense php-fpm[63138]: /rc.newwanip: rc.newwanip: Info: starting on re1.172.
May 29 21:20:26 pfsense php-fpm[63138]: /rc.newwanip: rc.newwanip: on (IP address: 192.168.172.1) (interface: IOT[opt2]) (real interface: re1.172).
May 29 21:20:26 pfsense php-fpm[63138]: /rc.newwanip: rc.newwanip: Info: starting on re1.173.
May 29 21:20:26 pfsense php-fpm[63138]: /rc.newwanip: rc.newwanip: on (IP address: 192.168.173.1) (interface: DMZ[opt4]) (real interface: re1.173).
May 29 21:20:54 pfsense php-fpm[40423]: /rc.newwanip: Gateway, none ‘available’ for inet6, use the first one configured. ‘WAN_DHCP6’
May 29 21:20:59 pfsense php-fpm[40423]: /rc.newwanip: Resyncing OpenVPN instances for interface WAN.
May 29 21:21:00 pfsense php-fpm[40423]: OpenVPN terminate old pid: 40769
May 29 21:21:00 pfsense kernel: ovpns1: link state changed to DOWN
May 29 21:21:00 pfsense check_reload_status: Reloading filter
May 29 21:21:00 pfsense kernel: ovpns1: link state changed to UP
May 29 21:21:00 pfsense php-fpm[40423]: OpenVPN PID written: 97083
May 29 21:21:00 pfsense php-fpm[40423]: /rc.newwanip: Creating rrd update script
May 29 21:21:00 pfsense check_reload_status: rc.newwanip starting ovpns1
May 29 21:21:02 pfsense php-fpm[40423]: /rc.newwanip: pfSense package system has detected an IP change or dynamic WAN reconnection - xxx.xxx.xxx.xxx → xxx.xxx.xxx.xxx - Restarting packages.
May 29 21:21:02 pfsense check_reload_status: Starting packages
May 29 21:21:31 pfsense php-fpm[82336]: /rc.newwanip: rc.newwanip: Info: starting on ovpns1.
May 29 21:21:31 pfsense php-fpm[82336]: /rc.newwanip: rc.newwanip: on (IP address: 192.168.100.1) (interface: ) (real interface: ovpns1).
May 29 21:21:31 pfsense php-fpm[82336]: /rc.newwanip: rc.newwanip called with empty interface.
May 29 21:21:31 pfsense check_reload_status: Reloading filter
May 29 21:21:31 pfsense php-fpm[82336]: /rc.newwanip: pfSense package system has detected an IP change or dynamic WAN reconnection - → 192.168.100.1 - Restarting packages.
May 29 21:21:31 pfsense check_reload_status: Starting packages
May 29 21:21:32 pfsense php-fpm[82336]: /rc.start_packages: Restarting/Starting all packages.
May 29 21:21:33 pfsense php-cgi: haproxy: reload old pid:41214
May 29 21:21:33 pfsense php-cgi: haproxy: started new pid:85655
May 29 21:21:37 pfsense php_pfb: [pfBlockerNG] filterlog daemon started
May 29 21:21:37 pfsense php: [pfBlockerNG] DNSBL parser daemon started
May 29 21:22:09 pfsense php-fpm[346]: /rc.start_packages: Restarting/Starting all packages.
May 29 21:22:10 pfsense php-cgi: haproxy: reload old pid:85655
May 29 21:22:10 pfsense php-cgi: haproxy: started new pid:38251
May 29 21:22:14 pfsense php: [pfBlockerNG] DNSBL parser daemon started
May 29 21:22:14 pfsense php_pfb: [pfBlockerNG] filterlog daemon started
May 29 21:22:28 pfsense check_reload_status: Syncing firewall
May 29 21:22:28 pfsense php-fpm[346]: OpenVPN terminate old pid: 97083
May 29 21:22:28 pfsense kernel: ovpns1: link state changed to DOWN
May 29 21:22:28 pfsense check_reload_status: Reloading filter
May 29 21:22:47 pfsense php-fpm[58663]: /rc.newwanip: Gateway, none ‘available’ for inet6, use the first one configured. ‘WAN_DHCP6’
May 29 21:22:52 pfsense php-fpm[58663]: /rc.newwanip: Resyncing OpenVPN instances for interface WAN.
May 29 21:22:53 pfsense php-fpm[58663]: OpenVPN PID written: 92970
May 29 21:22:53 pfsense check_reload_status: Reloading filter
May 29 21:22:53 pfsense kernel: ovpns1: link state changed to UP
May 29 21:22:53 pfsense php-fpm[58663]: /rc.newwanip: Creating rrd update script
May 29 21:22:53 pfsense check_reload_status: rc.newwanip starting ovpns1
May 29 21:22:55 pfsense php-fpm[58663]: /rc.newwanip: pfSense package system has detected an IP change or dynamic WAN reconnection - xxx.xxx.xxx.xxx → xxx.xxx.xxx.xxx - Restarting packages.
May 29 21:22:55 pfsense check_reload_status: Starting packages
May 29 21:23:23 pfsense php-fpm[43595]: /rc.newwanip: rc.newwanip: Info: starting on ovpns1.
May 29 21:23:23 pfsense php-fpm[43595]: /rc.newwanip: rc.newwanip: on (IP address: 192.168.100.1) (interface: ) (real interface: ovpns1).
May 29 21:23:23 pfsense php-fpm[43595]: /rc.newwanip: rc.newwanip called with empty interface.
May 29 21:23:23 pfsense check_reload_status: Reloading filter
May 29 21:23:23 pfsense php-fpm[43595]: /rc.newwanip: pfSense package system has detected an IP change or dynamic WAN reconnection - → 192.168.100.1 - Restarting packages.
May 29 21:23:23 pfsense check_reload_status: Starting packages
May 29 21:23:23 pfsense php-fpm[43595]: /rc.start_packages: Restarting/Starting all packages.
May 29 21:23:23 pfsense php-cgi: haproxy: reload old pid:38251
May 29 21:23:24 pfsense php-cgi: haproxy: started new pid:73827
May 29 21:23:27 pfsense php: [pfBlockerNG] DNSBL parser daemon started
May 29 21:23:27 pfsense php_pfb: [pfBlockerNG] filterlog daemon started
May 29 21:24:00 pfsense php-fpm[78137]: /rc.start_packages: Restarting/Starting all packages.
May 29 21:24:01 pfsense php-cgi: haproxy: reload old pid:73827
May 29 21:24:01 pfsense php-cgi: haproxy: started new pid:84623
May 29 21:24:05 pfsense php: [pfBlockerNG] DNSBL parser daemon started
May 29 21:24:05 pfsense php_pfb: [pfBlockerNG] filterlog daemon started
May 29 21:26:33 pfsense rc.gateway_alarm[52862]: >>> Gateway alarm: WAN_DHCP (Addr:xxx.xxx.xxx.xxx Alarm:1 RTT:70.295ms RTTsd:297.714ms Loss:21%)
May 29 21:26:33 pfsense check_reload_status: updating dyndns WAN_DHCP
May 29 21:26:33 pfsense check_reload_status: Restarting ipsec tunnels
May 29 21:26:33 pfsense check_reload_status: Restarting OpenVPN tunnels/interfaces
May 29 21:26:33 pfsense check_reload_status: Reloading filter
May 29 21:26:34 pfsense php-fpm[40423]: /rc.openvpn: Gateway, none ‘available’ for inet, use the first one configured. ‘WAN_DHCP’
May 29 21:26:34 pfsense php-fpm[40423]: /rc.openvpn: Gateway, none ‘available’ for inet6, use the first one configured. ‘WAN_DHCP6’
May 29 21:26:34 pfsense php-fpm[40423]: /rc.openvpn: OpenVPN: One or more OpenVPN tunnel endpoints may have changed its IP. Reloading endpoints that may use WAN_DHCP.
May 29 21:26:37 pfsense kernel: re0: watchdog timeout
May 29 21:26:37 pfsense kernel: re0: link state changed to DOWN
May 29 21:26:37 pfsense check_reload_status: Linkup starting re0
May 29 21:26:38 pfsense php-fpm[345]: /rc.linkup: DEVD Ethernet detached event for wan
May 29 21:26:39 pfsense check_reload_status: Reloading filter
May 29 21:26:40 pfsense kernel: arpresolve: can’t allocate llinfo for xxx.xxx.xxx.xxx on re0
May 29 21:26:41 pfsense kernel: arpresolve: can’t allocate llinfo for xxx.xxx.xxx.xxx on re0
May 29 21:26:42 pfsense kernel: arpresolve: can’t allocate llinfo for xxx.xxx.xxx.xxx on re0
May 29 21:26:42 pfsense php-fpm[82336]: /rc.linkup: DEVD Ethernet attached event for wan
May 29 21:26:42 pfsense php-fpm[82336]: /rc.linkup: HOTPLUG: Configuring interface wan
May 29 21:26:42 pfsense check_reload_status: rc.newwanip starting re0
May 29 21:26:42 pfsense php-fpm[82336]: /rc.linkup: calling interface_dhcpv6_configure.
May 29 21:26:42 pfsense php-fpm[82336]: /rc.linkup: Accept router advertisements on interface re0
May 29 21:26:42 pfsense php-fpm[82336]: /rc.linkup: Starting rtsold process
May 29 21:26:43 pfsense php-fpm[40423]: /rc.newwanip: rc.newwanip: Info: starting on re0.
May 29 21:26:43 pfsense php-fpm[40423]: /rc.newwanip: rc.newwanip: on (IP address: xxx.xxx.xxx.xxx) (interface: WAN[wan]) (real interface: re0).
May 29 21:26:44 pfsense php-fpm[82336]: /rc.linkup: Gateway, none ‘available’ for inet, use the first one configured. ‘WAN_DHCP’
May 29 21:26:44 pfsense php-fpm[82336]: /rc.linkup: Gateway, none ‘available’ for inet6, use the first one configured. ‘WAN_DHCP6’
May 29 21:26:44 pfsense check_reload_status: Restarting ipsec tunnels
May 29 21:26:51 pfsense check_reload_status: updating dyndns wan
May 29 21:26:51 pfsense check_reload_status: Reloading filter
May 29 21:27:52 pfsense rc.gateway_alarm[34714]: >>> Gateway alarm: WAN_DHCP (Addr:xxx.xxx.xxx.xxx Alarm:0 RTT:113.466ms RTTsd:400.123ms Loss:5%)
May 29 21:27:52 pfsense check_reload_status: updating dyndns WAN_DHCP
May 29 21:27:52 pfsense check_reload_status: Restarting ipsec tunnels
May 29 21:27:52 pfsense check_reload_status: Restarting OpenVPN tunnels/interfaces
May 29 21:27:52 pfsense check_reload_status: Reloading filter
May 29 21:27:53 pfsense php-fpm[346]: /rc.openvpn: Gateway, none ‘available’ for inet6, use the first one configured. ‘WAN_DHCP6’
May 29 21:27:53 pfsense php-fpm[346]: /rc.openvpn: OpenVPN: One or more OpenVPN tunnel endpoints may have changed its IP. Reloading endpoints that may use WAN_DHCP.
May 29 21:28:13 pfsense check_reload_status: Syncing firewall
May 29 21:28:21 pfsense rc.gateway_alarm[84792]: >>> Gateway alarm: WAN_DHCP (Addr:xxx.xxx.xxx.xxx Alarm:1 RTT:73.623ms RTTsd:311.320ms Loss:21%)
May 29 21:28:21 pfsense check_reload_status: updating dyndns WAN_DHCP
May 29 21:28:21 pfsense check_reload_status: Restarting ipsec tunnels
May 29 21:28:21 pfsense check_reload_status: Restarting OpenVPN tunnels/interfaces
May 29 21:28:21 pfsense check_reload_status: Reloading filter
May 29 21:28:21 pfsense check_reload_status: Syncing firewall
May 29 21:28:22 pfsense php-fpm[78137]: /rc.openvpn: Gateway, none ‘available’ for inet, use the first one configured. ‘WAN_DHCP’
May 29 21:28:22 pfsense php-fpm[78137]: /rc.openvpn: Gateway, none ‘available’ for inet6, use the first one configured. ‘WAN_DHCP6’
May 29 21:28:22 pfsense php-fpm[78137]: /rc.openvpn: OpenVPN: One or more OpenVPN tunnel endpoints may have changed its IP. Reloading endpoints that may use WAN_DHCP.
May 29 21:28:24 pfsense kernel: re0: watchdog timeout
May 29 21:28:24 pfsense kernel: re0: link state changed to DOWN
May 29 21:28:24 pfsense check_reload_status: Linkup starting re0
May 29 21:28:25 pfsense php-fpm[78137]: /rc.linkup: DEVD Ethernet detached event for wan
May 29 21:28:26 pfsense check_reload_status: Reloading filter
May 29 21:28:26 pfsense kernel: arpresolve: can’t allocate llinfo for xxx.xxx.xxx.xxx on re0
May 29 21:28:28 pfsense kernel: arpresolve: can’t allocate llinfo for xxx.xxx.xxx.xxx on re0
May 29 21:28:28 pfsense kernel: arpresolve: can’t allocate CLOG####�3##��######
