As the title says I have a custom domain and a pfSense box that I have setup to get a Let’s Encrypt cert through ACME.
I am using that Let’s Encrypt cert and custom FQDN for login on the pfSense firewall. This setup works most of the time, but every once in a while it will say the cert is invalid and will not let me access the firewall.
When this happens I have to login using the IP. I then go in and select a different login cert, save. Then go back and change the login cert back to the Let’s Encrypt cert and it works again until it doesn’t.
As best I can tell the Let’s Encrypt cert is renewing correctly, so I’m not sure why the login cert seems to randomly become invalid.
