Thanks for all the reply
@svirepi
I use the AIO at home 5 users and the memory consumption are very low (around 2gb)
..ok different scenario, here i need to test it, but I have a dual xeon (old silver) with 192gb so the power should be enough
@gaijin
I tried EuroOffice with some docx and the initial test are ..meh (so and so) the doc (40 pages with images, drawings and tables) is opened correctly but some pages are shifted down like it adds some new lines in between.. we will see.
Actually we use doc and xls for everything but we are slowly moving to Odoo, so the “paper” generated will be less.
Anyway this it is another thing to test (both formats MS and open)
@Louie1961
for this installation I mostly followed the Jay’s latest video.
I had only a problem with the installation of the raccomended apps (unable to fetch..) and the version 34, so I installed the 33 and then upgraded to the 34.
For the database instead I set up a small cluster with patroni etcd and postgres following the the TechnoTim video (more or less, because some procedures have changed. I also used my internal CA and added WAL backups to TrueNAS) and everything is put behind Traefik on docker.
I don’t know if it is overkill, maybe
, we will see..
I had no problems with the AIO too, as said I use it as my home cloud and I had never had problems. (if you want I can post my compose and traefik conf).
The Synology solution could be good but it needs a Synology NAS so I can’t test it, also I had a bad experience with it, I have one 4 bay at home and everything was working fine until, by pure chance, I found damaged files (the worst scenario, data loss and no warnings). I imagine was the ram/controller bacause I am still using the disks on truenas, but this is another story
@angriness5448
I use the docker at home, here instead I set up a vm with apache2, php & redis because if I remember correctly the AIO has some limitation (I don’t remember if 50 users or 50GB..)
I must install the Talk engine to complete the installation and it will be used only internally (as well as nextcloud, the only access from internet is with a VPN).
For the office suite, I set up eurooffice (a rebranded onlyoffice) because it should be more compatible with MS files (at least “on paper”).
My idea is to create team folders (like I do with AD) and map them on the windows clients with WebDav (so they can easy access to the files with file explorer and on the browser) but I must test everything (if I can mount the path with GPO, performance against smb, etc).
Unfortuntately as said, you can find a guide even to install it upside down, but there are very few information of real use case and how to do the things in the right way..
I found this channel, and even if the videos are 4 years old, it gaves me some useful tips and cleared up a few doubts about.
I don’t know if it is the algorithm or there are really no video about.
