I’m setting up a self hosted Invoice Ninja, and I’m importing all 400+ clients into it …
so far so good, only it doesn’t import the “country” field …
in the mapping stage of the import I nicely connect the country data into the “country” field, but after running the export, no counrty has been imported … all are empty …
Might it have something to do with the country-field being a drop down menu ?
should I replace the country name by a number code maybe ?
I have only 2 countries, Belgium and Netherlands … so it would be easy to replace the name by a number code if needed …
or might it have something to do with the language settings (language is set to “dutch” and in dutch “Belgium” is spelled “België” … should I maybe set the country name in English ?
Thanks in advance
Pascal
Belgium
