Can some one point me to straight forward instructions on how to install Immich on both Proxmox and Truenas that will allow me to store the main immich program on my nvme drive but allow my uploaded images and have storage of those images on my systems harddrives (storage tank with zsf pool) ??? thanks
Tom has a fairly extensive write-up on Immich w/ TrueNAS.
After a quick Google search, it seems as though there is a pre-defined LXC available on Proxmox you can use to install there:
If you do not wish to use LXC you can just create a linux VM and install Immich on the VM, at which point you’d just need to follow their install instructions.
The easiest way would be to just run Immich on the TrueNAS.
