I have used Proxmox for a couple of years on a PC and I thought it was finally time to graduate to a server. So I found a good deal on a Dell R720. It came loaded with an evaluation version of Win Serv 2016. Everything worked well. I could browse the internet with no trouble. I loaded Proxmox on the server (bc I know absolutely nothing about windows server) and while trying to update, I realized I could not reach the internet. I could not ping my router or 1.1.1.1. I could however ping other machines on my lan. I even tried pinging my lan with their host name and not just the IP. I spun up a VM with Ubuntu and everything works fine inside the VM. I can ping the router and the internet using IP or host name. I then tried booting a live version on MInt. Everything works as it should. I could browse the web and watch one Lawrence Systems videos on YouTube. I’ve looked through several forums and I see this problem, but rarely see a solution. I’ve posted on a few and after posting the results of ip a and cat /etc/network/interfaces I do not get further response. I’ve compared my results to other machine and it looks similar with only the IP and names of the NIC being different. I’m not sure if this is so simple it’s not worth their time or I have the worst problem ever. Either way, any help would be great. I understand that forums are not help desk and that my lack of knowledge in this makes it tougher, but if someone can point me in the right direction I would appreciate it very much. I am now loading XCP-NG to see if I have the same results.
Thank you all in advance,
NewGuy
Update: Loaded XCP-NG. 100% packet loss while pinging router at 192.168.86.1.
