I can't delete settings after a recovary
I need help ASAP pleas
context: i made a mistake and couldn’t get back into the pfsense GUI or in the console of my 2.8.0 ce box, so i reinstalled 2.8.0 right to the wizard and after, i re-imported my somewhat out of date backup xml file but got it back to where is was just before the crash (somewhat)
where thing are good: i remembered all the changes i had made and re-applied them and all seemed ok.
where thing are not so good: i noticed that i cant delete any setting that i need deleted or
i feel like i lost the ability to do a few things as if i had lost privileges
  • can’t delete
  1. ipv4 or DNSBL Groups in pfBlocker
  2. alias
  3. rules
  4. certificates
  5. port forwarding
  6. watchdog monitor servises
  7. DHCP static mapping
  • i can’t halt the system
  • and a few other thing
Am i right thinking i lost my privileges and the right to remove things and if so how on hearth do i correct the problem?
figured it out, it looks like HAproxy is not letting me edit some system setting as when i log in with ip address all works as it should
could it be my certificates?
Check the logs for an error message
