Looking to move from that traditionally endpoint security into a new solution that better protects our endpoints not only against AV, but malware and unknown threats, etc. Also, as the team here is very limited, need something that can look after itself and doesn’t need a lot of baby sitting. Sends pertinent notifications and won’t inundate you.
Been looking at Huntress, seems very hands off, leverages Defender now, looks like a good solution. Started a trial with their solution. A few other, larger, companies in my space though I know are using SentinelOne. I’m still waiting for pricing but I’m guessing it’s going to be more, but their product also seems more robust, looking at the Singularity Control solution.
Question is, how to decide? I have about 150 endpoints. Nothing to complicated. I know @LTS_Tom indicated they use both and I’m sure that is even better, but we will only be able to afford one, so how do I choose? One is a bit cheaper, but will do the job, one is pricier but is it worth the extra expense?
If anyone has experience with either that they could post briefly about, I would appreciate it. What did you like, not like, etc.
Thanks!
