In my network setup I have multiple VLANS. I have a problem with routing the traffic to a specific VLAN, in my case VLAN70 with the ip addresses 192.168.70.0/24. Routing to all other VLANS works.
I have tried everything I could think of:
- ping from server in VLAN60, with the result ‘Network is unreachable’
- nc (ncat) from server in VLAN60, also with the result ‘Network is unreachable’
- ping from the router, with the result ‘3 packets transmitted, 3 received, 0% packet loss’
- no firewall rules are active (default is that all traffic is allowed)
- inspected the routing table on the router (result of ‘ip route show’ below)
The setup worked and it just stopped working.
I have recently upgraded the software on the USG, but I am not sure if the problem started directly after the upgrade, or some time later. Since the upgrade I have restarted the USG by disconnecting the power for
N.B. The issue exists both for IPv4 and IPv6
Question:
What other tests can I perform to pinpoint the problem?
Any other suggestions?
Background information:
Router:
- type - USG Pro
- software - Linux MainRouter 3.10.107-UBNT #1 SMP Wed Apr 8 20:43:58 UTC 2020 mips64
- configuration - no firewall rules defined for IPv4 (only the standard/built-in rules). see the attached configuration file
The command ‘ip route show’ on the USG gives the following result:
admin@MainRouter:~$ ip route show
*default via 192.168.178.1 dev eth2 proto zebra *
*127.0.0.0/8 dev lo proto kernel scope link src 127.0.0.1 *
*192.168.44.0/24 dev eth0.44 proto kernel scope link src 192.168.44.1 *
*192.168.60.0/24 dev eth0.60 proto kernel scope link src 192.168.60.1 *
*192.168.70.0/24 dev eth0.70 proto kernel scope link src 192.168.70.1 *
*192.168.71.0/24 dev eth0.71 proto kernel scope link src 192.168.71.1 *
*192.168.99.0/24 dev eth0 proto kernel scope link src 192.168.99.1 *
*192.168.107.0/24 dev eth0.107 proto kernel scope link src 192.168.107.1 *
*192.168.113.0/24 dev eth0.113 proto kernel scope link src 192.168.113.1 *
*192.168.178.0/24 dev eth2 proto kernel scope link src 192.168.178.36 *
192.168.187.0/24 dev eth0.187 proto kernel scope link src 192.168.187.1
Ping from USG to server on the VLAN succeeds:
admin@MainRouter:~$ ping 192.168.70.5
PING 192.168.70.5 (192.168.70.5) 56(84) bytes of data.
64 bytes from 192.168.70.5: icmp_req=1 ttl=64 time=0.720 ms
64 bytes from 192.168.70.5: icmp_req=2 ttl=64 time=0.386 ms
