Just checking to see if anyone has done this before. I used to install the guest utilities by mounting the iso provided with XCP-ng, but there seems to be a newer rust based version of the guest utilities: Rust guest tools 0.3.0
I’m just trying apt purge xe-guest-utilities for now, but it’s unclear if that will delete everything.
You can use apt-get remove and it will remove the old versions. The purge option will also remove configuration settings but I don’t think there are any in the utils.
Yep, seems to have done it. Here’s an ansible playbook if anyone needs it:
- name: Deploy management agent on debian hosts
hosts: debian
tasks:
- name: Delete old agent
apt:
state: absent
purge: true
register: old_agent
- name: Reboot to clean old agent
reboot:
when: old_agent.changed
- name: Copy APT repository list
copy:
src: ./xen-guest-agent.list
dest: /etc/apt/sources.list.d/xen-guest-agent.list
owner: root
group: root
mode: 0644
- name: Install/update management agent
apt:
state: present
update-cache: true
