how to Allow your own domains name through captive portal instead of an ip address
You are going to have to elaborate a bit more on what the goal is.
Thank you for that , well i want to have domain on captive portal when use connect trough my pfsense server , so that they can’t able to see the ip Address am using .
thank you
It has been a while since I have setup a captive portal, but you need to have a pre-authorized list of sites, including your domain for it to work.
can you help me to show me the way how to do it
I have not used them in years, I don’t usually recommend them due to the headache they create getting devices connected. Try the Netgate forums https://forum.netgate.com/
