Hi all.
So i have a ironwolf 10tb with expired warranty and 2792 bad sectors, its in a raidz2 vdev. I know its never a good sign but how urgent it is to replace it?
Currently cant afford a new one, maybe in 2 or 3 months i could get a replacement… (not seagate, 2 out of the 4 hdd i ordered died this year)
Thanks in advance!
smartctl output:
root@zenifer[~]# smartctl -q noserial -a /dev/da4
smartctl 7.1 2019-12-30 r5022 [FreeBSD 12.2-RC3 amd64] (local build)
Copyright © 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Seagate IronWolf
Device Model: ST10000VN0004-1ZD101
Firmware Version: SC60
User Capacity: 10,000,831,348,736 bytes [10.0 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun Oct 25 11:53:27 2020 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 246) Self-test routine in progress...
60% of test remaining.
Total time to complete Offline
data collection: ( 575) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 891) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x50bd) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 083 064 044 Pre-fail Always - 215608984
3 Spin_Up_Time 0x0003 086 086 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 228
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 2792
7 Seek_Error_Rate 0x000f 095 060 045 Pre-fail Always - 2867265464
9 Power_On_Hours 0x0032 068 068 000 Old_age Always - 28103 (57 91 0)
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 97
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 083 083 000 Old_age Always - 17
190 Airflow_Temperature_Cel 0x0022 059 051 040 Old_age Always - 41 (Min/Max 26/44)
191 G-Sense_Error_Rate 0x0032 094 094 000 Old_age Always - 13976
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 16
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 293
194 Temperature_Celsius 0x0022 041 049 000 Old_age Always - 41 (0 23 0 0 0)
195 Hardware_ECC_Recovered 0x001a 031 001 000 Old_age Always - 215608984
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0023 100 100 001 Pre-fail Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 28005 (178 91 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 55261933697
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 187459220269
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Self-test routine in progress 60% 28103 -
# 2 Short offline Completed without error 00% 27923 -
# 3 Short offline Completed without error 00% 27755 -
# 4 Short offline Completed without error 00% 27587 -
# 5 Extended offline Completed without error 00% 27530 -
# 6 Short offline Completed without error 00% 27419 -
# 7 Extended offline Completed without error 00% 26626 -
# 8 Short offline Completed without error 00% 26412 -
# 9 Short offline Completed without error 00% 25668 -
#10 Short offline Completed without error 00% 24948 -
#11 Extended offline Completed without error 00% 24418 -
#12 Short offline Completed without error 00% 24036 -
#13 Extended offline Completed without error 00% 24007 -
#14 Short offline Completed without error 00% 23317 -
#15 Short offline Completed without error 00% 22574 -
#16 Extended offline Completed without error 00% 22261 -
#17 Short offline Completed without error 00% 21878 -
#18 Short offline Completed without error 00% 21134 -
#19 Short offline Completed without error 00% 20390 -
#20 Short offline Completed without error 00% 19670 -
#21 Short offline Completed without error 00% 18928 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
(bad sector count still 2792)
