Hi, Everyone.
I hope you can help me with my issue. I have pfsense and on the dashboard it is showing 100% CPU utilization and it is not going away. I perform “top -aSH” and below is the screenshot of the result
which shows 3 insstance “bzip2 -f /var/log/filter” and 1 instance of “/usr/local/sbin/filterlog” are all running at 67%.
I have tried the following to try to fix this:
- reset log files
- restart pfsense
- turn off the system log daemon
- disable send logs to remote syslog server
- Increase log rotation count to 15
But none work, any suggestion that may help fix this issue?
Device information:
Pfsense is installed in a protectli box and using 250 GB of SSD drive and using pfsense+ 22.01
