Hello Lawrence Systems folk!
First of all — Tom’s YouTube guides have been INVALUABLE. What a phenomenal body of work for the internet. Thank you.
Of course however I’m here because I’m stuck!
I’ve spent quite a bit of time between a rock and a hard place trying to be able to connect via SSL to one particular server running on a proxmox VM on my home LAN using HAProxy on Pfsense.
Current setup:
- I have a a few servers running in a couple of different VLANs for different purposes: pihole, proxmox, etc.
- Created wildcard certificate for
mydomain.com/*.mydomain.comin ACME - Set up HAProxy backends for these servers + frontend with SSL offloading
- I can access
https://pihole.mydomain.com,https://proxmox.mydomain.com, etc. all with zero issues — happy me… except for this new problem:
On Proxmox (which I’m recently converted to), there is 1 VM (Ubuntu Server) that’s running a database index with no webUI front-end (you connect with apps).
I can use my desktop software to connect to the index today by typing the IPv4 ssl://192.168.10.3 on port 50002 and the connection is successful + traffic is encrypted using a self-signed certificate on the VM.
However, I want to connect to ssl://index.mydomain.com:50002via a reverse proxy for SSL termination, as the mobile apps I use to connect require a valid SSL certificate.
I’ve set up HAProxy backend to point index to 192.168.10.3 on port 50002 with Encrypt (SSL) checked and SSL checks unchecked.
On the frontend, I already have the Listen Address as the Proxmox VLAN interface for port 443 (for the services with webUIs), so I added a new row, same interface, with port 50002 and SSL offloading checked.
Access control list and backend are just as the webUI services, and DNS resolver is configured also.
Using this, I could never get the service to connect and 50 youtube videos later was giving up. In the end, I added a NAT rule to port forward 50002 between HAProxy on the VLAN interface (192.168.10.1) and the IP of the VM itself (192.168.10.3) — amazing! I can connect.
EXCEPT — I get man-in-the-middle warnings, handshake failure warnings… always warnings. And the mobile apps won’t connect.
Using openssl I think I have identified the problem, but I’m not sure what I’ve done wrong:
When I run openssl s_client -servername index.mydomain.com -host 192.168.10.1 -port 50002 with the port forwarding enabled, I receive confirmation of the self-signed certificate. I can connect to the server with SSL warnings that I can ignore on desktop, but not on mobile.
With port forwarding disabled & running the same query, I receive confirmation of the wildcard certificate (what I expected), but I cannot connect to the server.
It’s been several days/weeks that I’m fiddling around here with this. Any help would be much appreciated!
