Hi Folks - I am back to pulling my hair out in trying to get HAProxy to do this simple thing:
- Internal URL http://192.168.10.250/axis-cgi/mjpg/
- External URL https://livewx.pelleys.com - removes the path
I have tried in Backend pass thru:
http-request replace-uri ^/(.*) /axis-cgi/mjpg/\1- doesn’t work, ends up in users’ browser trying to go to http://192.168.10.250/axis-cgi/mjpg/ (obviously not going to work from the Internet)http-request set-path /axis-cgi/mjpg/- doesn’t work, 503 error
There is a second site, no rewriting/shortening required, that works just fine; e.g. https://devweb.pelleys.com to http://192.168.10.1.
Of course, redirecting to my old internal nginx (yes, reverse proxy to reverse proxy) works:
location / {
include proxy_params;
proxy_pass http://vidsrv2.pelleys.com:80/axis-cgi/mjpg/;
allow all;
What am I missing here?
Here is the full generated configuration
frontend frontend_https
bind 47.55.69.140:443 name 47.55.69.140:443 ssl crt-list /var/etc/haproxy/frontend_https.crt_list
mode http
log global
option http-keep-alive
option forwardfor
acl https ssl_fc
http-request set-header X-Forwarded-Proto http if !https
http-request set-header X-Forwarded-Proto https if https
timeout client 30000
acl acl_livewx var(txn.txnhost) -m str -i livewx.pelleys.com
acl acl_devweb var(txn.txnhost) -m str -i devweb.pelleys.com
acl aclcrt_frontend_https var(txn.txnhost) -m reg -i ^([^\.]*)\.pelleys\.com(:([0-9]){1,5})?$
http-request set-var(txn.txnhost) hdr(host)
use_backend backend_livewx_ipvANY if acl_livewx aclcrt_frontend_https
use_backend backend_devweb_ipvANY if acl_devweb aclcrt_frontend_https
mode http
id 100
log global
http-response set-header Strict-Transport-Security max-age=31536000;
timeout connect 30000
timeout server 30000
retries 3
load-server-state-from-file global
server vidsrv2 192.168.10.100:443 id 101 ssl verify none
mode http
id 102
log global
http-check send meth OPTIONS
retries 3
option httpchk
server extweb 192.168.10.1:80 id 103 check inter 1000
