Since the update to the latest version of pfSense, our HAProxy doesn’t work anymore.
This message I get when trying to start the HAProxy in the pfsense dashboard:
Cannot open command socket, HAProxy not running? (Connection refused) Cannot open command socket, HAProxy not running? (Connection refused)"
and is visible in the log: systemlog
Dec 5 16:16:18 pfsm php-fpm[34706]: haproxy: check error output: [NOTICE] (94833) : haproxy version is 2.8.3-86e043a [NOTICE] (94833) : path to executable is /usr/local/sbin/haproxy [WARNING] (94833) : config : Loading: Unable to parse OCSP response. Content will be ignored. [WARNING] (94833) : config : Loading: Unable to parse OCSP response. Content will be ignored. [WARNING] (94833) : config : Loading: Unable to parse OCSP response. Content will be ignored. [WARNING] (94833) : config : Loading: Unable to parse OCSP response. Content will be ignored. [WARNING] (94833) : config : Loading: Unable to parse OCSP response. Content will be ignored. [NOTICE] (94833) : config : config: Can’t open global server state file ‘/tmp/haproxy_server_state’: No such file or directory Warnings were found. Configuration file is valid
the only message I see in the haproxy/log is:
Dec 11 12:03:10 pfsm haproxy[76748]: 192.XXX.X.XX:XXX45 [11/Dec/2023:12:03:10.571] Primary-107-APP-merged/XX.XXX.XX.107:443: SSL handshake failure (error:0A000076:SSL routines::no suitable signature algorithm)
I can’t figure it out. I just restored the pfsense with a 1 month old bakup and still the haproxy is not responding as it should. besides the previously reported error messages, nothing changes. I also have a snapshot of the linked volume, but I am afraid to use it :(. My setup consists of 2 different pfsense servers. 1 master server and one slave. The servers communicate with each other through CARP. What I am afraid of is if I restore the server with the snapshot that the IP addresses/ wan, lan and sync will come to decay and maybe even the slave will break. Without the slave all the linked portals go down and I am much further from home. Perhaps I am worrying about nothing but are these possible risks or are the riscos not so bad?
after debugging some of the not working services. i get this error: The request was aborted: Could not create SSL/TLS secure channel. But all the frontends have valid certificates. Do i mis somthing?
