So I have HA proxy working with sonarr,deluge,jacket,etc. Radar and heimdell are showing good status in HAproxy. If I understand correctly PFsense Rewrite the configuration file every time haproxy starts. My 1st question is where do I find this temporary config file to compare The services that are working versus the services that are not
I have never had to touch it, but the HAProxy config is located at
/var/etc/haproxy/haproxy.cfg
And that file is built from using the web interface and as far as I know will be overwritten if any web interface changes are made.
Thank you i got it working. I had a dns entry in dns resolver i had forget about.
Great that you have it fixed, as the saying goes “It’s always DNS”
So I am currently having another issue with sonarr. My current configuration has not changed in the last two years. When I try and log into Sonarr. I get a “failed to load Series from API” Message.
I can connect directly to the IP.
