Hello All! I have some HA proxy issues. I have used Tom’s HA Proxy 2023 video and have my pfsense up and running using HA proxy via home(dot)hunting1sand0s(dot)com on the 155.1.100.0/24 network (Production). I wanted to add a few new items so I can get rid of the SSL errors. The first FQDN is globalunifi(dot)hunting1sand0s(dot)com on the (MGMT) network 172.16.100.0/24 and node(dot)hunting1sand0s(dot)com one for (MGMT) 172.16.100.0/24 and (Production) 155.1.100.0/24 network. My pfsense setup works great to access the firewall but the other two give me 503 errors. What did I miss? TIA for the assist!
When you ping the FQDN of these devices what IP Addresses do you get? Sounds like a dns issue. I had one when I setup Nextcloud and Colabora that I had to work through.
What is haproxy bound to on the front end? I believe it is 155.
I believe you are not even going through haproxy. If you shutdown haproxy and try using the FQDN I am expecting you will still get a 503 error. If not it is something else.
Try setting up a frontend to tied to 172.16.100.1 and remove the entries to 155 network. Or leave haproxy as is and point the host override to 155.1.100.1. I am assuming you are trying to access internally.
