GRT leaking through Pfsense
Hello, could you please explain what needs to be done to make this situation work properly. The company has implemented network segmentation using VRF. All traffic from VRF goes through PFsense. I want to make a GRT leak to VRF. I did a VRF receive command. It works well I can access internal IP addresses from an external vlan, but when I want to access a web that has mapped external IP 1: 1 on the Pfsense - I can’t access it. When I run the tracert command, it does not know where that external IP address is located. Could you help me, please?
That is not something I have done with pfsense, if no one here has any suggestions you may wan to try the Netgate Forums. https://forum.netgate.com/
