I have been following the Graylog: Your Comprehensive Guide to Getting Started Open Source Log Management. Which works perfectly of course. I have also used Ubuntu 22.04. Unfortunately my Linux skills are very basic so please take that into consideration.
I am a little confused on how to setup the log data to go to a cifs share on a NAS.
I have added a share in fstab and was able to mount the share ok:
Thank you I did try - “/media/graylog_data:/usr/share/opensearch/data” however I then get the following error on bringing docker up:
graylog | 2024-01-25 10:21:09,613 ERROR: org.graylog2.storage.versionprobe.VersionProbe - Unable to retrieve version from Elasticsearch node: Failed to connect to opensearch/172.18.0.2:9200. - Connection refused.
graylog | 2024-01-25 10:21:09,615 INFO : org.graylog2.storage.versionprobe.VersionProbe - Elasticsearch is not available. Retry #8
It’s not a issue for me to just run local storage as I only need this for pfsense openvpn logs.
