Graylog 5.14 - TrueNAS Jail and HTTPS / TLS Communication
Hello Community,
i’ve all ready installed (manualy) an Graylog5 Server in a TrueNAS Jail 13.2. It’s reachable and usable as required but without HTTPS / TLS communication trough the web interface. there are a lot of links “how to / useing HTTPS / …” shown by google but no realy solution,if it’s running in a TrueNAS Jail.
My issue is, the Java Keystore is not existing on the host. There are different OpenJDK versions 7 / 11 / 15 installed, and i’ve noi dea how to implement certificates from my internal PKI infrastructure into Graylog to get an HTTPS and secure communication established.
Any idea / experiance how to establish HTTPS / TLS communication to Graylog successfully to use it for Switches, Unifi Controller and Firewalls ?
Thx forward
Andy
You don’t need HTTPS to get your switches and services sending logs. I really don’t like messing around with the java keystore and all that jazz. I just setup a reverse proxy (nginx or HAproxy) and call it a day.
@xMAXIMUSx
thx for your reply. HJave you ever installed an Apache rev.-proxy for Graylog and perhapse an guidline (topics / guideline) how it works ?
Regards
Andy
Hello to all,
after hard work I got NGINX running as a reverse proxy for Graylog on the same host. thanks to @xMAXIMUSx
Regards
Andy
Problem fixed. NGINX rev.-proxy solved the issue and it’s reachable trough standard HTTPS link
