Hi, This is the second time i tried to install FreeRadius on a fresh Pfsense. I just received a 2100 from Netgate. Had the community version on it. We updated it and it went to 21.02. We installed FreeRadius and setup the server and noticed the service was not started. We tried to restart it and failed. Looking at the logs we see this.
| Apr 6 12:52:46 | radiusd | 92963 | Debugger not attached |
| Apr 6 12:52:46 | radiusd | 93393 | Unable to check file /usr/local/etc/raddb/certs/server_key.pem: No such file or directory |
| Apr 6 12:52:46 | radiusd | 93393 | /usr/local/etc/raddb/mods-enabled/eap[26]: Failed parsing configuration item private_key_file |
| Apr 6 12:52:46 | radiusd | 93393 | rlm_eap_tls: Failed initializing SSL context |
| Apr 6 12:52:46 | radiusd | 93393 | rlm_eap (EAP): Failed to initialise rlm_eap_tls |
| Apr 6 12:52:46 | radiusd | 93393 | /usr/local/etc/raddb/mods-enabled/eap[2]: Instantiation failed for module eap |
We tried to uninstall and reinstall with the same message. This happen before and i copied over the server_key.pem from another Pfsense and the service was able to start and no more issues.
Anyone else seeing this? Thoughts? They were both Netgate 2100 that i saw this.
