I am having issues setting up my FreePBX on VoIP.ms using TLS. Unencrypted works fine but when I follow these two guides (TLS and SRTP - Phones - Documentation & https://wiki.voip.ms/article/Call_Encryption_-_TLS/SRTP) I cannot get the FreePBX server to register with VoIP.ms. I am not sure what I am doing wrong here.
[2022-01-14 22:20:32] WARNING[7974]: res_pjsip_outbound_registration.c:824 schedule_retry: VoIP.ms_Trunk: No response received from 'sip:washington1.voip.ms:5061' on registration attempt to 'sip:000000@washington1.voip.ms:5061', retrying in '60'
[2022-01-14 22:21:04] ERROR[7974]: res_pjsip.c:4350 endpt_send_request: Error 320047 'No answer record in the DNS response (PJLIB_UTIL_EDNSNOANSWERREC)' sending OPTIONS request to endpoint VoIP.ms_Trunk
ucs*CLI> pjsip show registration VoIP.ms_Trunk
<Registration/ServerURI..............................> <Auth..........> <Status.......> <Last Reg..> <Intvl> <Next Start.....secs>
VoIP.ms_Trunk/sip:washington1.voip.ms:5061 VoIP.ms_Trunk Rejected Fri 22:34:14 60 Fri 22:35:14 6
ParameterName : ParameterValue
auth_rejection_permanent : false
client_uri : sip:000000@washington1.voip.ms:5061
contact_user :
endpoint : VoIP.ms_Trunk
expiration : 3600
fatal_retry_interval : 30
forbidden_retry_interval : 30
line : true
max_retries : 10000
outbound_auth : VoIP.ms_Trunk
outbound_proxy :
retry_interval : 60
server_uri : sip:washington1.voip.ms:5061
support_path : false
transport : 0.0.0.0-tls
