After updating FreeNas to 11.2-U2.1, Freenas no longer loads the available plugins and it doesn’t show any system updates. I’m not sure if these problems are related? It seems it can’t access these files online. I primarily use FreeNas for Plex and to backup photo’s from our phones.
Someone did mention that a failing boot drive can cause weird problems. I have mirrored USB drives and from time to time I do get an error saying one of the boot drives has degraded. I tried to remove the USB’s one at a time and they both booted individually without any errors. I plugged them both back in and again no errors. This boot degrade is random and doesn’t happen very often.
When I click on Available Plugins I eventually get this error. Maybe someone understand it? I don’t
I would like to keep things up to date.
Any help is greatly appreciated. Thanks
<urlopen error [Errno 60] Operation timed out>
Error: concurrent.futures.process._RemoteTraceback:
Traceback (most recent call last):
File “/usr/local/lib/python3.6/urllib/request.py”, line 1318, in do_open
encode_chunked=req.has_header(‘Transfer-encoding’))
File “/usr/local/lib/python3.6/http/client.py”, line 1239, in request
self._send_request(method, url, body, headers, encode_chunked)
File “/usr/local/lib/python3.6/http/client.py”, line 1285, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File “/usr/local/lib/python3.6/http/client.py”, line 1234, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/usr/local/lib/python3.6/http/client.py”, line 1026, in _send_output
self.send(msg)
File “/usr/local/lib/python3.6/http/client.py”, line 964, in send
self.connect()
File “/usr/local/lib/python3.6/http/client.py”, line 1392, in connect
super().connect()
File “/usr/local/lib/python3.6/http/client.py”, line 936, in connect
(self.host,self.port), self.timeout, self.source_address)
File “/usr/local/lib/python3.6/socket.py”, line 724, in create_connection
raise err
File “/usr/local/lib/python3.6/socket.py”, line 713, in create_connection
sock.connect(sa)
TimeoutError: [Errno 60] Operation timed out
During handling of the above exception, another exception occurred:
File “/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_plugin.py”, line 646, in fetch_plugin_index
self.__clone_repo(git_server, git_working_dir)
File “/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_plugin.py”, line 1258, in __clone_repo
porcelain.pull(destination, repo_url, errstream=devnull)
File “/usr/local/lib/python3.6/site-packages/dulwich/porcelain.py”, line 818, in pull
path, r, progress=errstream.write, determine_wants=determine_wants)
File “/usr/local/lib/python3.6/site-packages/dulwich/client.py”, line 363, in fetch
progress)
File “/usr/local/lib/python3.6/site-packages/dulwich/client.py”, line 1398, in fetch_pack
b"git-upload-pack", url)
File “/usr/local/lib/python3.6/site-packages/dulwich/client.py”, line 1282, in _discover_references
resp, read = self._http_request(url, headers, allow_compression=True)
File “/usr/local/lib/python3.6/site-packages/dulwich/client.py”, line 1261, in _http_request
resp = self.opener.open(req)
File “/usr/local/lib/python3.6/urllib/request.py”, line 526, in open
response = self._open(req, data)
File “/usr/local/lib/python3.6/urllib/request.py”, line 544, in _open
‘_open’, req)
File “/usr/local/lib/python3.6/urllib/request.py”, line 504, in _call_chain
result = func(*args)
File “/usr/local/lib/python3.6/urllib/request.py”, line 1361, in https_open
context=self._context, check_hostname=self._check_hostname)
File “/usr/local/lib/python3.6/urllib/request.py”, line 1320, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [Errno 60] Operation timed out>
File “/usr/local/lib/python3.6/concurrent/futures/process.py”, line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File “/usr/local/lib/python3.6/site-packages/middlewared/worker.py”, line 128, in main_worker
res = loop.run_until_complete(coro)
File “/usr/local/lib/python3.6/asyncio/base_events.py”, line 468, in run_until_complete
return future.result()
File “/usr/local/lib/python3.6/site-packages/middlewared/worker.py”, line 88, in _run
return await self._call(f’{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
File “/usr/local/lib/python3.6/site-packages/middlewared/worker.py”, line 81, in _call
return methodobj(*params)
File “/usr/local/lib/python3.6/site-packages/middlewared/schema.py”, line 668, in nf
return f(*args, **kwargs)
File “/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py”, line 502, in list_resource
header=False)
File “/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py”, line 914, in fetch
icon=True, official=official)
File “/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_plugin.py”, line 653, in fetch_plugin_index
_callback=self.callback)
File “/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py”, line 90, in logit
_callback(content, exception)
File “/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py”, line 64, in callback
raise callback_exception(message)
RuntimeError: <urlopen error [Errno 60] Operation timed out>
The above exception was the direct cause of the following exception:
File “/usr/local/lib/python3.6/site-packages/middlewared/main.py”, line 165, in call_method
result = await self.middleware.call_method(self, message)
File “/usr/local/lib/python3.6/site-packages/middlewared/main.py”, line 1141, in call_method
return await self._call(message[‘method’], serviceobj, methodobj, params, app=app, io_thread=False)
File “/usr/local/lib/python3.6/site-packages/middlewared/main.py”, line 1078, in _call
return await self._call_worker(serviceobj, name, *args)
File “/usr/local/lib/python3.6/site-packages/middlewared/main.py”, line 1105, in _call_worker
job,
File “/usr/local/lib/python3.6/site-packages/middlewared/main.py”, line 1036, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File “/usr/local/lib/python3.6/site-packages/middlewared/main.py”, line 1021, in run_in_executor
return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs))
