I am trying to setup nextcloud on my freenas server but I am having some issues. I have found the video on YouTube https://www.youtube.com/watch?v=ETdlrNUGjZk but I am confused how i can set it up on mine freenas.
My Pools on my freenas server are in the picture I have uploaded.
There is also another very popular installation method written by danb35 on the freenas forums which I’m aware a lot of other people have used as well:
There are a lot of ways to skin the cat however and I’ve been tempted to run the docker installation and just mount the volumes within the container – only problem is that Freenas and docker don’t really mix well together – if only if Freenas had a linux kernel – yet another dream I guess particular now with ZOL.
So my question is, I am trying to install NextCloud on FreeNAS, when I finish install the Jail and trying to log I. To the NextCloud via web, I get error, please see picture.
I SSH into freenas and issue this command: (change path where appropriate)
nano /mnt/ [name of pool] /iocage/jails/ [name of freenas instance] /root/usr/local/www/nextcloud/config/config.php
which uses nano to edit the config.php but you can also use vi if you prefer.
You can also launch a shell into the nextcloud jail from the Freenas GUI, expand the nextcloud instance using the ‘>’ at the right of the instance and select shell. Once there you can edit the config.php file found in /usr/local/www/nextcloud/config/ ( I cd ino each directory to verify that I have the correct path) and then use vi to edit)
