Hi, everyone I setup a pfSense with a VLAN10 (10.10.6.x) as my main network for Workstation, Switch , Access Point and Servers. I don’t use the DHCP server of the pfSense for VLAN10 and I’m wondering how can I force my users to use Pi-Hole with IP addr of 10.10.6.2 for example?
For other VLANs that I have like VLAN30 I have pfSense DHCP server and manually added the Pi-Hole server…
For some reason my LAN is just there for Management…
I did disable the DNS resolver of my pfSense, deleted hard coded DNS servers under " System > General Setup ", and force to use Remote DNS server, ignore local DNS.
I’m thinking adding an alias for ports like 53 and 850 then use it on VLAN10 with Source inverted to Pi-Hole IP addr and DEST to the port alias.
