I recently bought a house and started on my home network. Though I am facing a problem and can’t find the solutions anywhere. I have fiber network to the home. I have connected it to a pfSense box. The pfSense desktop has only one LAN available. So I have connected a Dell powerconnect 2808 managed switch to it. I am trying to create two seperate VLAN and connect two AP to them so they don’t talk to each other. I have created two VLAN on the switch and the pfSense (HC for home network and HC IOT for IOT devices). One AP is a plume mesh wifi setup connected to the port 2 (VLAN HC) of the switch. Another AP is a TP-Link archer AX11000 connected to port 3 of the switch (VLAN HC IOT). But the TP-Link router is still connecting to the main LAN. If I disable the DHCP server of the TP-Link router and disable NAT on it then no device is connecting to it. Seems like the IOT VLAN is not providing DHCP service to the TP-link router. And if I keep DHCP server and NAT enabled then the devices connected to the IOT network and ping other devices which I am trying to block. Here are some screenshots:
Can you point me to the right direction? Any help is highly appreciated.
