I actually have one more question about my UniFi home network setup. I have a UDR7 router and two wired UX7 as Access Points. My question is whether it’s possible to configure the UX7’s LAN output to be on VLAN2 (IoT Network)? I’ve looked everywhere, but I haven’t found a setting for it. When I look at the connected client, it is displayed as a VLAN1 client (Default Network), but I have no idea where or even if it is possible to change it to VLAN2. For the UDR7 ports, the VLAN’s selection is straightforward.
In the UniFi system create a new network for IoT apply the proper zone (DMZ would be fine) then under WiFi create an IoT WiFi and choose that network you created for the IoT.
Go into the port manager and choose the Native VLAN / Network for that port then choose “Block All” if you only that network to be available on that port.
