Hello Everyone,
I am reaching out to this forum in the hopes that someone can either instruct me on how to fix my issue or provide a guide that would allow me to get my TrueNAS
server connected to my two esxi 7 hosts. At present I am not able to get the esxi hosts to connect to the TrueNAS server.
From the truenas server I can ping the ip addresses of the vmkernal nic ip addresses, however when connected to each of the esxi server via ssh I am not able to ping back to the TrueNAS server when trying to git 172.10.10.100 and 172.10.20.200
I have followed the following tuts with out any of them resolving the connectivity issue.
- Building a Lab Part 3 Configuring VMWare ESXI and TrueNAS Core
- Add iSCSI Shared Storage to VMware ESXi-Arm - Virtualization Howto
I’m hoping someone has either done this or can provide instructions that I can follow that will help me out. I’m at my wits end here.
Thank you in advance.
Below is my current configs, let me know if I am missing data that can help with resolving this.
TrueNAS Server Info
Interfaces:
- alco (1GB not used)
- em0 - 10.1.1.211 (1GB Used for webinterface)
- bxe0 - 172.10.10.100 (10GB Used for iSCSI connection) <------> ESXi1 (172.10.10.2)
- bxe0 - 172.10.20.200 (10GB Used for iSCSI connection) <------> ESXi2 (172.10.20.2)
Storage:
main-pool
-esxi-store0 (Type=volume)
iSCSI:
-Target Global Configuration:
BaseName: iqn.2005-10.org.freenas.ctl
- Portals:172.10.10.100:3260,172.10.20.200:3260
iSCSI-Portals
Listen = 172.10.10.100:3260,172.10.20.200:3260
Initiators:
set to allow all
Authorized Access (not configured yet)
Targets:
Target Name: iscsi-targets
Portal Group ID: 1 (iSCSI-Portal)
Initiator Group ID: 1 (ALL Initators Allowed)
Auth Method (None)
Extents:
Extent Type: Device
Device: main-pool/esxi-store0
Logical Block Size: 512
Enable TPC is checked
LUN RPM: SSD
Associated Target
Target: iscsi-target
LUN ID: 0
Extent:
iscsi-extent
ESXI Server info:
ESXI1: Standard Switch (vSwitch1)
VLAN ID: –
- VMKernel Ports (1)
vmk1: 172.10.10.2
VMKerneladapters:
vmk1:
- TCP/IP stack: storage (This stack has a gateway of 172.10.10.1)
- IPv4 setting: 172.10.10.2
Subnet: 255.255.255.0
Storage Adapter:
Name vmhba66
Model iSCSI Software Adapter
iSCSI Name iqn.1998-01.com.vmware:esxi2.lenape.home:1541370251:68
iSCSI Alias iscsi_vmk
Target Discovery Send Targets, Static Targets
- Dynamic Discovery:
- 172.10.10.100:3260
-Static Discovery:
172.10.10.100:3260, Target = iqn.2005-10.org.freenas.ctl
Network Port Binding:
Unable to add this as the selection is not select-able (I was able to select this when the vSwitch PortGroup used the default tcp/ip stack)
ESXI2: Standard Switch (vSwitch1)
VLAN ID: –
vmk1: 172.10.20.2
VMKerneladapters:
vmk1:
- TCP/IP stack: storage (This stack has a gateway of 172.10.20.1)
- IPv4 setting: 172.10.20.2
Storage Adapter:
Name vmhba68
- 172.10.10.200:3260
-Static Discovery:
172.10.10.200:3260, Target = iqn.2005-10.org.freenas.ctl
