Error when saving HAProxy
Hi Tom,
I am following this tutorial on HAProxy
When I enable HAProxy, I get the following error:
Could you please tell me if you came across that before and if you know how to fix it?
Thank you
Instead of a screen shot you should post the error message:
/tmp/haproxy_server_state
There are some posts in the Netgate forums about that error.
Hi ,
Sorry about that. I also get this when trying to save the fontend settings
Errors found while starting haproxy
[NOTICE] (74986) : haproxy version is 2.8.3-86e043a
[NOTICE] (74986) : path to executable is /usr/local/sbin/haproxy
[ALERT] (74986) : config : parsing [/var/etc/haproxy_test/haproxy.cfg:15] : 'bind 95.21x.xxx.xxx:443' in section 'frontend' : 'crt-list' : unable to load certificate from file '/var/etc/haproxy_test/TRI_Servers.pem': no start line.
[ALERT] (74986) : config : Error(s) found in configuration file : /var/etc/haproxy_test/haproxy.cfg
[ALERT] (74986) : config : Fatal errors found in configuration.
There is the problem, not sure why but that cert has an issue.
Thank you. I’ll rewatch the video from begining
