Hi
I configure openvpn server with dual wan but when i switch to the other interface it does not connect
what do i need to adjust on interface settings to make it work
Hi
Open up the ports for each WAN interface.
Ok let me go full detail on what I have done
We have the openserver setup using localhost
I have dn port forwarding for both Interface 1194 and set as target ip as 127.0.0.1 for both wan interface
Then I export the configuration to user PC
I forgot to add on client export page
I chang interface to multiwan forward ip
Add
Remote-randon
Remote 10.10.10.10 udp
Remote 11.11.11.11 udp
And export configuration to user
I believe when user tries to connect to the first ip if it is not reachable it goes to the second ip vice versa
You need the port numbers.
Sounds like it should be working, perhaps check each WAN connection works by independently first.
pfsense has documentation on how to get this working here
https://docs.netgate.com/pfsense/en/latest/multiwan/openvpn.html
I will send a screenshot of config as soon as I get home
