My goal is to use my mobile phone LTE connection as second Internet gateway in case of problems with my cable connection.
I watched Toms video about the topic
It works almost.
I use dns resolver on my pfSense maybe this is a problem with dual failover?
Wen i disconnect the cable network connection it failsover to the LTE connection as it should.
In a Windows command box i can ping ip’s but dns is not working.
If i test “nslookup google.com 9.9.9.9” this works also but the default DNS, the pfsense lan ip doesn’t work to resolve dns requests.
I tried everything i could think of but sadly no go.
Maybe somebody here on the forum knows what i could have overlooked?
I selected the second wan in de resolver outgoing networks.
To test i enabled “DNS Query Forwarding”.
I have several (Quad9) dns servers configured in system > general setup.
Wen i manually configure a dns server in my windows client network settings it works i can surf the net.
If i set the network settings to auto it doesn’t work.
Make sure under “System General → DNS Server Settings” you have the gateway set to none and under “Services → DNS Resolver General Settings → Outgoing Network Interfaces” you have “ALL” chose.
