I’m stumped…
I’ve been running a cable internet connection for years… Utilizing the ISP device as provided, it contains both the modem and a 4-port switch. I’ve had the ISP configure my connection to provide 2 dynamic IP addresses. Really simple, just plug and go…
Full Unifi network from headend, to tail end, 2 USG’s, Switches, and AP’s all running off my controller…
Now, I’m going to be going to convert my connection to a Fibre Optic connection with an ISP provided single port ONT. They have indicated that I’m going to be able to derive 2 IP addresses from that device.
Cool, I’m told that all I need to do is place an additional switch between my ONT and the 2 USG’s. Ok I can handle that…
Here’s my dilemma, should I use a dumb switch? I don’t really see just how a Unifi managed switch would work in the instance…
Or, have I missed something, overlook the obvious etc… any suggestion would be of great help…
Cheers….
