I am having some dramas with my Telco and I would like to track my sync speeds (or close enough to) as well as my drop outs so that I can produce evidence of my claims to them.
I am running pfSense and pihole (for my DNS and DHCP) as VMs.
Are there any plugins for these that will track sync speeds and dropouts or do I need another application or VM?
P.S Apologies if I seem a little incoherent - my 3 kids kept me up most of the night I am barely functioning.
pfSense logs should be able to give you a record of wan dropouts as it should be set up to keep latency and down stats. For speeds, I’m sure someone will have a better idea than I, but I’d set up a cron job using iperf between two sources and log everything.
3 kids, at least you have a good shot of getting cared for in old age, so that’s worth being incoherent at times.
Lol
Ok cool, I’ll have to check out the logs when I get home or at some point over the weekend. I was thinking of creating a Cron job with iperf but hoping for a better solution - I’ll wait and see if anyone else has any other ideas.
Cheers for the advice
You could also spin up a Zabbix VM (or docker container) to get more detailed traffic statistics in one place (in case there is more than 1 pfSense box).
