I have been using docker on VM for ages and suddenly now I can not create new containers but once done I cannot stop or delete them. Ok so I must have changed something at some point but I can’t remember what or when. Tried restoring a backup which did not help so must have made the changes ages again.
When I try I get “Error response from daemon: cannot stop container: xxxxxxx: permission denied”
I have apt-get update and upgrade on the VM, tried restarting the docker service but to no avail.
I would have thought that if I can create and start containers that the user should also have permission to stop it.
If I can crash the container (buy removing a directory and then restarting the VM) then I can delete the container or update and restart it (once I put the directory back).
Apologies for the late reply; been one of those weeks.
sysadmin@services:~$ su -
Password:
root@services:~# docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
28e6f12796b8 ghcr.io/hay-kot/homebox:latest "/app/api /data/conf…" 9 days ago Created 81fa35949d57_homebox
81fa35949d57 ghcr.io/hay-kot/homebox:latest "/app/api /data/conf…" 9 days ago Up 9 days 0.0.0.0:3100->7745/tcp, :::3100->7745/tcp homebox
d14b7b6b4bfc guacamole/guacamole "/opt/guacamole/bin/…" 6 months ago Up 9 days 0.0.0.0:8080->8080/tcp, :::8080->8080/tcp my-guacamole
8e55e3ef9563 guacamole/guacd "/bin/sh -c '/opt/gu…" 6 months ago Up 9 days (healthy) 4822/tcp my-guacd
80e95d6186a6 8189e588b0e8 "docker-entrypoint.s…" 10 months ago Up 9 days 3306/tcp, 33060/tcp guacamole-mysql
633ed7835c27 lscr.io/linuxserver/heimdall:latest "/init" 10 months ago Up 9 days 0.0.0.0:80->80/tcp, :::80->80/tcp, 0.0.0.0:443->443/tcp, :::443->443/tcp heimdall
7e7b7e0d0e0f cloudflare/cloudflared:latest "cloudflared --no-au…" 10 months ago Up 9 days cloudflaretunnel
root@services:~# docker container stop homebox
Error response from daemon: cannot stop container: homebox: permission denied
root@services:~#
root@services:~#
root@services:~# sudo systemctl disable apparmor.service --now
Synchronizing state of apparmor.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install disable apparmor
root@services:~# service apparmor stop
