That box was already unchecked but still wasn’t about to see the Quad9 or openDNS when running a DNS leak test. Though I was able to fix it by going to Services / DNS Resolver / General Settings and checking the DNS Query Forwarding box and then it immediately grabbed the DNS I set back in system settings. Not sure if it’s the right way but it is what worked.
Is there some way to monitor what Quad9 is filtering ? I am using Open dns with an account and i can see stats and what is going on. Does Quad9 offer this too ? ( or am i missing this feature because my google skills failed ) sips coffee
I ran your script with just 10 hosts, column E always returns 45.32.196.109 Why is that?
Domainname,1.1.1.1,9.9.9.9,1.1.1.2,103.247.36.36,208.67.222.222
hmora.fred-build.tk,195.20.46.190,,0.0.0.0,45.32.196.109,195.20.46.190
borat.elticket.com.ar,,,,45.32.196.109,
pave.elisecries.com,35.235.101.253,,35.235.101.253,45.32.196.109,35.235.101.253
lay.elticket.com.ar,,,,45.32.196.109,
peeg.fronterarq.cl,,,,45.32.196.109,
lexu.goggendorf.at,127.0.0.2,,127.0.0.2,45.32.196.109,127.0.0.2
malibu.websitewelcome.com,192.185.179.134,192.185.179.134,192.185.179.134,45.32.196.109,192.185.179.134
msw67.cafe24.com,116.120.57.94,,116.120.57.94,45.32.196.109,116.120.57.94
ktechi.com,176.9.166.34,176.9.166.34,176.9.166.34,45.32.196.109,176.9.166.34
walfab.com,198.185.159.145,198.49.23.144,198.185.159.145,45.32.196.109,198.49.23.144
Hi - you had asked about a management interface for Quad9. There is no way to monitor Quad9’s filtering via a web interface at Quad9, since we do not have the concept of an “account” due to privacy and data collection issues. However, if you are willing to do a bit of hackery, then it is possible to see which queries are being blocked by our filter versus which queries are being naturally given an NXDOMAIN. We flag our blocked queries with the RD bit in the reply. If you’re using Quad9 as a forwarder, Pi-Hole automatically recognizes this and will flag the blocks appropriately, but it’s possible to just capture the packets manually as well.
If you’re a user of tshark (the command-line version of wireshark for Linux) then you could run a command like this constantly to get a list of blocked hosts. Of course, change the ethernet interface for your local installation, and that interface would need to be able to “see” all the query replies coming from Quad9 towards your host(s). This loops to prevent disk exhaustion since tshark keeps temp files. Use “dig @9.9.9.9 +short A blocked.test.on.quad9.net” to trigger a block result.
while true; do tshark -np -i ens32 -q -c 100000 -E separator=, -E quote=d -T fields -e frame.time_epoch -e dns.qry.name -e ip.src -e ipv6.src -e ip.dst -e ipv6.dst -Y “dns.flags.rcode eq 3 && dns.flags.recavail eq 0” “src net 9.9.9.0/24 or src net 149.112.112.0/24 or src net 149.112.149.0/24 or src net 2620:fe::0/48” 2>/dev/null; done
Hi BangkokBob - We actually have a system in Bangkok at a local IX (Inter-eXchange) called BKNIX (https://www.peeringdb.com/ix/1025) in our Packet Clearing House space (they’re another non-profit that is the primary way we get distributed worldwide.) If your provider doesn’t peer (exchange packets) with us there, then they take the packets wherever they see fit. PCH has an open interconnect policy, meaning they’ll interconnect with any network at no cost as long as they’re on the IX. However, many telcos (they always seem to be telcos) have a somewhat antiquated view of the world and think that interconnecting for better performance is a negative (that is a much longer myth than can be explained here) so they may decide that taking your traffic to an entirely different nation or even continent is the “best” thing to do. Apply pressure locally for your ISP/telco to connect to open exchanges and your performance will improve, not just to Quad9 but to everything. Other organizations may choose to pay or otherwise compensate the ISP/telco to interconnect, but we feel that is a bad precedent for an open and robust Internet, and rewards poor architectural decisions.
Switched from OpenDNS Home Free to Quad9 many years ago since OpenDNS did not support DNSSEC or DNS over TLS. Set up pfSense FW rules to route all DNS queries through UNBOUND. Works perfectly.
@quad9dns Now if we can only get pfSense to adopt DNSCrypt natively.
Any chance you could add cleanbrowsing and webtitan to your test? There’s an older test by Nykolas Z out there that shows cleanbrowsing beating quad9 and opendns on phishing domains. Curious how cleanbrowsing compares for malware domains.
elvisimprsntr - Is DNS-over-TLS good enough? That works today with recent releases of pfSense. Just add these lines to the “Custom Options” in your DNS Resolver:
server:
forward-zone:
forward-ssl-upstream: yes
forward-addr: 2620:fe::fe@853
forward-addr: 9.9.9.9@853
forward-addr: 149.112.112.112@853
Don’t worry - having the IPv6 address in there won’t hurt anything; it just gets skipped if you don’t have IPv6.
Hi there,
I’m a security researcher at DNSFilter, and I was very interested to see this test. I’ve spent a while looking into it because I was surprised by the results, and had a few comments. I had planned to reply yesterday, but my Saturday went a bit askew so I haven’t had a chance until now.
First of all, full credit for explaining your testing procedure and providing details of your test data and the script run. This is great to see, because as you say in your video it allows others to run things in their own environment.
Unfortunately, I think the test data used wasn’t a great source for malicious domains. The obvious indicator here is that the initial list was ~2200 entries long, but you ended up with only 141 after filtering out domains that no longer resolve.
I had a look further into this, and the source (hxxps://isc.sans.edu/suspicious_domains.html) notes its sources. Here’s a quick rundown from the list on that page:
Malware Domain List. com (hxxp://www.malwaredomainlist.com/updatescsv.php)
- only has four entries, two of which aren’t actually domains
Domain Blocklist From Malwaredomains (hxxp://mirror1.malwaredomains.com/files/domains.txt)
- malwaredomains.com has been deprecated and not updated for a long time
Threatexpert .com Malicious URLs (hxxps://www.networksec.org/grabbho/block.txt)
- completely blank file
Virustotal Domains
- no actual URL linked to here, and VirusTotal don’t have a public feed of malicious domains
Checking a copy of the list on GitHub (hxxps://github.com/Ultimate-Hosts-Blacklist/DShield.org-Suspicious-Domain-List-High/commits/master/domains.list) shows that very little has changed in the source list for a long time.
It’s tough to find decent public sources of malware. This is actually part of my job, assessing third-party feeds which we can ingest into our system to help improve our filtering, and we’re in the process of integrating several new feeds right now. We’ve also deprecated several in the past few months, because they’re just not good enough quality - they have a high percentage of false positives, and don’t offer very much protection.
I’ve re-run the test locally, and can already see that even with the remaining domains there are some issues. There’s a couple of very weird results (ie, IPs being different from different resolvers), and a lot of domains that don’t have any accessible services or content anymore. I need to go through the list properly to give a decent report, though.
I would provide a decent public source you could use for domains to use in this test, but I don’t want there to be any suggestion of bias. However, we’d love to work with you to improve the test, because honestly we want the same thing: decent protection from online threats. Please get in touch!
Thanks again for being open about your testing, I really do have to commend your transparency here.
cheers,
- Peter
PS: URLs have been lightly obfuscated because there’s a limit of 2 URLs per post for new users. Feel free to edit this post to properly link them up.
Hello from Greece. Been following Tom on YouTube but this video gave me a reason to signup on the forum.
I recently switched to Quad9 (57ms latency) from Cloudflare (17ms latency) since the latter was giving me some blank replies on some DNSSEC-enabled zones. I also found that Quad9 is more transparent in their documentation and provide more granularity (e.g. I am using the “Blocklist, DNSSEC, EDNS Client-Subnet sent” service).
I do advocate Quad9 to my peers but the latency discussion is always a show stopper. @quad9dns is there any plans for a closer to the home service (i.e. Easter Europe)? We are currently being served by London.
Just for the fun of it, here’s my forward section of my DNS resolver box (unbound) at home. I forward google and cloudflare related queries to their DNS services
and the rest to Quad9 ![]()
# Google related queries to 8.8.8.8
forward-zone:
forward-addr: 2001:4860:4860::8888@853
forward-addr: 8.8.8.8@853
forward-addr: 2001:4860:4860::8844@853
forward-tls-upstream: yes
forward-zone:
forward-zone:
forward-zone:
forward-zone:
forward-zone:
forward-zone:
forward-zone:
forward-zone:
forward-zone:
forward-zone:
forward-zone:
forward-zone:
forward-zone:
forward-zone:
forward-zone:
forward-zone:
forward-zone:
forward-zone:
forward-zone:
forward-zone:
forward-zone:
# Cloudflare related queries to 1.1.1.1
forward-zone:
forward-addr: 2606:4700:4700::1111@853
forward-addr: 1.1.1.1@853
forward-addr: 2606:4700:4700::1001@853
forward-zone:
forward-zone:
forward-zone:
## All the rest to upstream (currently quad9)
forward-zone:
forward-addr: 2620:fe::11@853 # quad9.net secondary
forward-addr: 9.9.9.11@853 # quad9.net primary
forward-addr: 2620:fe::fe:11@853 # quad9.net secondary
Hi, many thanks for your answer. I pay my ISP a tidy sum each month so hope I have leverage. Exactly what is it that I would ask them to do? I understand what you have written, but I can’t quite see how I would phrase a request to them. TIA
Thank you @peter I will reach out directly via email.
Could you post this list, I’m interested.
Hey Kolok. Which list do you mean? I posted links to several, but the main source mentioned in the video is this one:
I was referring to this .
DNS-over-TLS is good enough, and this post seems to indicate better. https://tenta.com/blog/post/2017/12/dns-over-tls-vs-dnscrypt
The only thing I liked about OpenDNS Home Free is the content filtering. I configured pfSense to use DNS-over-TLS with OpenDNS servers which seemed to work, unfortunately OpenDNS (Cisco) doesn’t officially support it. Since malware protection is higher priority, I switched to Quad9, and have been extremely pleased with availability and performance.
P.S. pfSense 2.4.4+ DNS-over-TLS can be configured via the GUI and does not require custom settings. See link at bottom of post. https://www.netgate.com/blog/dns-over-tls-with-pfsense.html
Hi mtheofy - We actually have quite a few locations and servers spread out across Europe; it’s one of our densest geographic regions, because of national borders and density of IX infrastructure. Greece, sadly, is not one of our POPs - yet. But London seems a bit far, I agree. If we’re not immediately nearby, then your provider has much more control over where the handoff is than we do. We have a list of locations where we have systems and interconnections here: https://www.quad9.net/locations Note that your provider would need to peer with Packet Clearing House (PCH - AS42) at one or more of those locations for the traffic to have a chance to be locally served. We are big advocates of dense, localized traffic exchange. Keeping your DNS queries in the same nation in which they were originated improves performance, security, and privacy. However, that requires the cooperation and participation (investment) of local network providers such as telcos and ISPs, so that is sometimes contradictory to their internal goals.
Thanks for the reply John @quad9dns
Will reach out to some connections I still have with GR-IX and a couple of major ISPs. No promises on any quick success though.
Keep up the great work
mtheofy - Thanks! That would be great. You can reference your contacts to the peering data at PCH - they’re our primary partner for getting footprint worldwide. Typically, if they can get connected to the IX, they provide us with a small amount of rackspace and some transit so we can get our services installed. https://www.pch.net/about/peering
