Is there a way to have a template setting for an Unifi network with several AP, for instance, change the Radio settings for all AP to auto, etc. So I don’t have to configure each individual device manually.
Ole
Ole
I believe, by default, the controller automatically gives all of the APs the same settings. I know that’s how mine worked. I can also go in and adjust individual APs afterwards, if desired.
I believe you re right, but what if you wanted to change the setting on a high number of AP´s then manual is the not funniest way.
So a kind of template or blueprint associated with a number of AP’s is what I am looking for
Hi Ole,
I just confirmed in my UniFi CloudKey controller that you can do that.
It’s under Settings >> Wireless Networks
Changes made there provision to all devices.
Hope that helps,
Sean
