Hi,
i have a ruckus r610 unleashed network up and running.
At a more remote location i would like to use a tp-link with ddwrt as a client bridge system.
i just need a little network there, no big performance and the client i try to connect has no ability for wifi itself.
but i cant get this ddwrt client bridge to work properly.
I try to configure it as dexcribed here
its connection to the wifi, fine…
i can reach the webUI of ddwrt via my other comouter, fine…
i can ping my gateway router connected to the isp from my client which is connected to the ddwrt router only…, fine…
but the client on the lan-interface of the ddwrt doestn get a dhcp adress from my gateway and i cant connect to the internet.
so if i put a static ip for my laptop, connect it via cable to the ddwrt, i can ping my gateway and any other client on the network but no internet!
and dhcp doenst receive a proper IP…
although now i got an ip over dhcp for now… dont know what i did different
could someone tell me what am i missing?
thanks a lot
Stefan
