I have an XCP-NG server with multiple VMs running on it. I want to move the server to a different place in the house, and I only have one ethernet cable running from that location to my home office. I want to be able to access multiple different networks from my home office. I have a catalyst switch and have set up a VLAN trunk port in order to accomplish this. This is my configuration:
Gi0/1
switchport trunk encapsulation dot1q
switchport mode trunk
switchport trunk allowed vlan all
I have other ports on the switch configured with vlans 10, 20 and 30.
I was able to get connectivity when plugging devices into access ports on the switch with the same vlans assigned, as expected.
But as a test, I created a VLAN interface on my linux box and set it to 30. Assigned an IP to that interface, and I can’t ping it.
My assumption is that if I tag the VLAN from within linux, the catalyst switch is going to route it to the correct access ports on the switch. Am I wrong? Or did I configure my trunk port incorrectly?
Any help would be appreciated.
