Yesterday morning i received an alert from my TRUENAS server “* Pool VDEV state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected”
So went to check on the system the pool status was showing online and big cross next to it. Checked the disks and one disk was showing 2 error under checksum for one disk. However on checking the smart tests, it was showing completed without error. But when i checked the smart parameters i found 2 concerning lines
5 Reallocated_Sector_Ct
191 G-Sense_Error_Rate
I guessed this disk was failing and needs to be replaced and got busy getting the invoice for a RMA.
Later in the day i had power failure in area which triggers a shutdown of TrueNAS. Today after powerup when i checked the server, the alert was gone, there is no trace of that alert or the error anywhere. The Pool status is back to normal Online and Tick next to it.
I checked the disk that was showing the error and the SMART parameters still show the same values but everything else seems fine. The checksum errors are zero.
So what do i gather from this, it was a transient error or does the hard disk needs replacement ?? I cant figure out how the error corrected itself until and unless the reboot cleared out all the errors. But that not right because if the hard disk is going to fail the error should be more permanent.
Now i am not sure if i should send the disk for a RMA, more importantly I am not sure if the vendor will accept the disk for RMA with just these 2 error lines.
Sounds like there was an CRC error that was corrected when the system restarted. The drive vendors vendors sometimes want their tests run on the drive before allowing an RMA. Look for the RAW_VALUE number for Reallocated_Sector_Ct to show some bad sectors to know there is an issues.
I did check and these 2 parameters have values when they should be zero
Reallocated_Sector_Ct has a raw value of 8
G-Sense_Error_Rate has a raw value of 4959
I checked informally with my vendor and he says usually HDD RMA services are outsourced to third parties and they accept RMA only if the HDD fails the tests of their utility. Or SMART reports major errors.
In the case above SMART passes successfully and does not report any error.
I’d still buy a spare and have it ready. But this is not the first time I’ve seen something similar on mine and I think it went another 2 years before giving more problems. I upgraded my entire pool at that time because I needed more storage anyway.
Just to update on this issue. Something weird is happening. I now have 2 disks showing checksum error. The earlier disk that was causing this error is no longer showing this error. These are 2 different disks. But the SMART data on both disk is clean. Further the errors disappear after i reboot machine and then in about 30 minutes the error comes back. I notice the errors come during the scrub process running before the errors come.
I am running TrueNAS-13.0-U2 and just upgraded the Pool to get the benefits of the new ZFS changes. This was done about a week back. The error has been showing up from yesterday.
Any idea how to troubleshoot this error. The screenshot of the error is shown below.
This is for the first disk - which shows 3 checksum errors
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p1 amd64] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Toshiba MG04ACA... Enterprise HDD
Device Model: TOSHIBA MG04ACA600E
Serial Number: 60QXK370FTMB
LU WWN Device Id: 5 000039 a1c701554
Firmware Version: FS4B
User Capacity: 6,001,175,126,016 bytes [6.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Fri Sep 16 15:02:38 2022 IST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 120) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 631) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
2 Throughput_Performance 0x0005 100 100 050 Pre-fail Offline - 0
3 Spin_Up_Time 0x0027 100 100 001 Pre-fail Always - 10227
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 107
5 Reallocated_Sector_Ct 0x0033 100 100 050 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 100 100 050 Pre-fail Offline - 0
9 Power_On_Hours 0x0032 072 072 000 Old_age Always - 11426
10 Spin_Retry_Count 0x0033 102 100 030 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 105
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 33
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 11
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 110
194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 38 (Min/Max 22/50)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 253 000 Old_age Always - 0
220 Disk_Shift 0x0002 100 100 000 Old_age Always - 0
222 Loaded_Hours 0x0032 072 072 000 Old_age Always - 11425
223 Load_Retry_Count 0x0032 100 100 000 Old_age Always - 0
224 Load_Friction 0x0022 100 100 000 Old_age Always - 0
226 Load-in_Time 0x0026 100 100 000 Old_age Always - 541
240 Head_Flying_Hours 0x0001 100 100 001 Pre-fail Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 11398 -
# 2 Short offline Completed without error 00% 11350 -
# 3 Short offline Completed without error 00% 11285 -
# 4 Short offline Completed without error 00% 11237 -
# 5 Short offline Completed without error 00% 11189 -
# 6 Short offline Completed without error 00% 11141 -
# 7 Short offline Completed without error 00% 11117 -
# 8 Short offline Completed without error 00% 11059 -
# 9 Short offline Completed without error 00% 10980 -
#10 Extended offline Completed without error 00% 10979 -
#11 Short offline Completed without error 00% 10932 -
#12 Short offline Completed without error 00% 10884 -
#13 Short offline Completed without error 00% 10860 -
#14 Short offline Completed without error 00% 10812 -
#15 Short offline Completed without error 00% 10792 -
#16 Short offline Completed without error 00% 10744 -
#17 Short offline Completed without error 00% 10720 -
#18 Short offline Completed without error 00% 10672 -
#19 Short offline Completed without error 00% 10659 -
#20 Short offline Completed without error 00% 10635 -
#21 Short offline Completed without error 00% 10588 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
This is for the Second Disk which shows 78 checksum errors
Serial Number: 60QWKGQ8FTMB
LU WWN Device Id: 5 000039 a1c680f76
Local Time is: Fri Sep 16 15:02:33 2022 IST
been run.
command.
power-saving mode.
recommended polling time: ( 638) minutes.
3 Spin_Up_Time 0x0027 100 100 001 Pre-fail Always - 10266
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 105
5 Reallocated_Sector_Ct 0x0033 100 100 050 Pre-fail Always - 8
9 Power_On_Hours 0x0032 072 072 000 Old_age Always - 11436
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 103
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 5478
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 8
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 108
194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 40 (Min/Max 23/52)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 1
222 Loaded_Hours 0x0032 072 072 000 Old_age Always - 11435
226 Load-in_Time 0x0026 100 100 000 Old_age Always - 543
No Errors Logged
# 1 Short offline Completed without error 00% 11409 -
# 2 Short offline Completed without error 00% 11361 -
# 3 Short offline Completed without error 00% 11295 -
# 4 Short offline Completed without error 00% 11247 -
# 5 Short offline Completed without error 00% 11199 -
# 6 Short offline Completed without error 00% 11151 -
# 7 Short offline Completed without error 00% 11127 -
# 8 Short offline Completed without error 00% 11069 -
# 9 Short offline Completed without error 00% 11022 -
#10 Extended offline Completed without error 00% 11000 -
#11 Short offline Completed without error 00% 10980 -
#12 Extended offline Completed without error 00% 10979 -
#13 Short offline Completed without error 00% 10932 -
#14 Short offline Completed without error 00% 10884 -
#15 Short offline Completed without error 00% 10860 -
#16 Short offline Completed without error 00% 10812 -
#17 Extended offline Completed without error 00% 10806 -
#18 Extended offline Aborted by host 50% 10794 -
#19 Short offline Completed without error 00% 10744 -
#20 Short offline Completed without error 00% 10720 -
#21 Short offline Completed without error 00% 10672 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
EDIT Sorry Just noticed that the second disk was the same one that reported and error last time. But i changed the position of the disk in my array. hence the device name got changed. But the first disk is showing no SMART errors
EDIT: Update. I shutdown the server removed, cleaned and reattached all the HDDs and HDD cables and powered up the server. So far the error has not recurred.
Generally speaking, it looks like your drives should have plenty of life left in them. Might just be an odd firmware glitch, is there a newer firmware that you can apply?
All that said, I haven’t used Fujitsu in a very long time. Since these are Enterprise grade, I’d expect them to live for a good long time.
Cables that are not fully seated in their connectors and / or have to sharp of bends (improper radius-ed) can cause these types of errors. Such errors may be intermittent showing up as the system temperature changes. Start with the basics and work up the ladder of complexity.
