Hi, I’m having trouble configuring ZeroTier on Freenas. I want to make an offsite backup for my data and I would like to use zerotier for comunicating betwen my boxes. I was able to install zerotier on my box and I can connect to ZeroTier server. The problem is, that after an restart all configurations disapear. I tried using crontab, but it clear’s it aswell and every time I want to connect manually, the zerotier server asign’s a new IP to my server. I would very apriciate your help.
That should be fixed in the latest version
https://redmine.ixsystems.com/issues/77790
If not there is a post in their forums here about how to get it working, I have never tested it as I don’t use it with FreeNAS.
Thank you very much. It works great now
