Hi guys, I have a linux server with cockpit installed. In the cockpit GUI I have configured three network interfaces for the server. However when I restart the server, one of the interfaces (ens18) is put into disabled state.
I found this netplan config on the server, which I suspect is overwriting the configuration in cockpit on reboot. I tried disabling this configuration file by giving it a .bak extension and running sudo netplan apply.
However after the next reboot I was unable to reach any of the network interfaces and had to recall the snapshot I made prior.
Do you guys have any suggestions how to solve this?
Not sure if this is the issue, but I found a GitHub link about a similar issue where netplan stores the configuration under /run/NetworkManager/ while Cockpit is saving its config under /etc/NetworkManager/. They end up concluding that it’s not supported, but I wonder if you could symlink one to the other.
I was able to solve this with a workaround by forcing the desired configuration using the Netplan configuration file. However this is ofcourse not the ideal situation as I probably now have to remember to change to configuration in two places if I at some point want to change the IP address for that interface for example.
