I’m sure there’s an easy fix/explanation here but I can’t seem to get it working.
I have a chromecast setup and have it working across vlans with the Avahi service on pfSense.
I use a pi-hole for most of the devices on my network but not all. If I connect my phone for example to the pi-hole for DNS I lose access to my chromecast within the YouTube app. If I just put my DNS back to 1.1.1.1 it can see the Chromecast fine.
Is there a setting that I need to enable on the pi-hole to allow the chromecast to work with local machines using it for DNS?
Avahi is setup on pfsense to assist with chrome cast but if you have pi-hole for DNS and the upstream is cloud flare then there isn’t any assistance from pfsense
It might be but, you aren’t querying pfsense for DNS then which is how avahi works. If you are pointing your dns to pi-hole and then upstream to cloud flare then your devices won’t be seen
