I’m having some internet dropouts on my gaming desktop. (internet drops out for 15 seconds or less) I have checked the system logs in my pfSense firewall and don’t see any high ping times or gateway issues reported by dpinger when the internet drops out on my desktop.
I have my desktop connected to a US-16-XG at 2.5G with a 10G module model UF-RJ45-10G Revision 2.
I know on Cisco you can show interface counters, but couldn’t find anything similar on Unifi dashboard. My Google foo found a reddit post from 6 years back that wasn’t helpful as the Unifi has been overhauled, and some references to accessing log files through the CLI, but I feel like there has to be some other way to access that information. If not, to the CLI I go.
Hi, I have just done some playing and hope the following might help. I will throw a warning out though. Anything you do is at your risk. I have done the following on my own XG-16 10 gb switch.
First check if you have Device SSH authentication enabled located in under the System settings.
If enable and you can see a unique username / password. Continue.
ssh into the XG-16. User the username / password defined.
once you are connected
Telnet 127.0.0.1 (you should see the command prompt like (ubnt) >
type enable
now you can run some familiar types of commands, like show run etc.
