CGNAT port forwarding issues and alternatives
Hi everyone. I have a problem im trying to find a solution for and I’m hitting a wall. Here’s the details
  • I have a location with an internal server that needs to be reached from the web.
  • The server cant be moved to another location or hosted on the cloud it MUST remain on site.
  • This site has a lack of good internet solutions, the only option was DSL or 5G home which is what we’ve been using.
I had this setup and working with the 5G home but the internet would get unberably slow once they are unprioritized for using too much data, so I just swithched to Starlink to test it and they are very happy with the speeds and performance.
My issue now is Starlik uses CGNAT so I can’t port forward and reach the internal server. Does anyone have any suggestions for getting around this or some solution I may not have though about?
Thanks in advance for any help.
2 options
  1. You can get a static IP address from starlink.
  2. You can setup tailscale or netbird
Thanks for the quick reply, I wasn’t aware I could get a public IP through Starlink. I read that this wasn’t offered and couldn’t find a way to do it, but I might have been reading old information. I’ll look into this further. The second option won’t work as it’s not a person but a service that needs to access the internal server and I have no control over that resource.
If it is a business account you can. Not sure about consumer. I know they do because I set one up this year for a business.
Tailscale funnel can do what you want.
Yeah they were on a residential account so that option wasn’t available. Thanks for your help, I’d not used Starlink before so wasn’t familiar. I haven’t used Tailscale either, that is very interesting. I’ll have to look into this and test it out.
Many of us that are forced into CGNAT use a VPS and setup a Tailscale or VLAN between the VPS and our home labs and other services. T-Mobile and AT&T for 5G internet do not offer a static IP for non-Business accounts and as stated above Starlink does the same.
The only issue I has with the VPS is that my inbound email to my personal E-Mail server had SPF checking turned on. And traversing the VPN tunnel uses NAT for inbound IP addresses thus any site that sent email and had a valid SPF record was being rejected due to the address being the interface of the host end of the tunnel. I had to turn off the SPF checking feature in my E-Mail server and things are back to normal minus the extra protection SPF checking provides.
So far, it’s costing me about $6/month for my DigitalOcean VPS that hosts HA proxy to route in web services , and native IP tables to bring in TCP apps such as E-Mail services and others.
